My MPi is running perfectly now and thinks for the Forum for your advice on the cooling system! It's done the run to & from work, a round trip of some 75 miles, for several days now and an extremely accurate fuel MPG check (brim full to brim full) has given a reading of 47.5 MPG-not bad for a car that moved like a stabbed rat on occasions!
The tick-over speed has settled down at 800 RPM once it's warm and is only about 1,100 when it's cold, which is just what I thought it should be. However, when the fan cooling fan cuts in, after a spirited run or a stand in traffic, the revs rise to 1,500 and on one occasion 2,000, which is unnerving, to say the least. Oddly enough, when I switch the engine off, leave it for about 10 seconds & start it again it behaves perfectly!
Is this an engine management problem that needs a computer to fix (I can get hold of one) or is it something more prosaic? Any ideas?
