Engine Rattle
16 replies to this topic
#1 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,034 posts
Posted 02 May 2014 - 06:38 PM
I noticed today that my engine has started rattling, it happens when idleing when I rev it, if I push the throttle in a bit it rattles as in the video below (if I push the throttle in slower it doesn't happen). I left the clutch in and tried it and it didn't happen. Could it be the thrust bearing?
It's a 998 1985 Ritz
click on the image below to play the video, it first happens at 6 seconds then around 9 secs,12s...
Cheers Alex
#2 alex-95
alex-95
  • 6,034 posts
Posted 02 May 2014 - 08:05 PM
bump
#3 Gremlin
Gremlin
  • 2,142 posts
Posted 02 May 2014 - 08:16 PM
Videos not working for me
#4 alex-95
alex-95
  • 6,034 posts
Posted 02 May 2014 - 08:29 PM
hmm, does for me, if you click it it should go to photobucket page and then play.
#5 Gremlin
Gremlin
  • 2,142 posts
Posted 02 May 2014 - 09:06 PM
Doesn't sound good, sounds like mains or big ends
#6 alex-95
alex-95
  • 6,034 posts
Posted 02 May 2014 - 10:16 PM
thanks, any more opinions?
#7 Gremlin
Gremlin
  • 2,142 posts
Posted 02 May 2014 - 10:19 PM
Piston slap
#8 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 02 May 2014 - 10:26 PM
Sounds like a transit. Also sounds terminal. :-|
#9 Gremlin
Gremlin
  • 2,142 posts
Posted 02 May 2014 - 10:49 PM
To make it clear, it didn't happen when you pushed the clutch in and tried it?
#10 alex-95
alex-95
  • 6,034 posts
Posted 03 May 2014 - 07:03 AM
yep didn't happen when the clutch was pushed in.
#11 Gremlin
Gremlin
  • 2,142 posts
Posted 03 May 2014 - 07:36 AM
Well this would suggest something to do with the thrust bearings, but I can't imagine they would make that sort of noise. Wait for more expertise to comment
#12 jpw1275
jpw1275
  • 2,803 posts
Posted 03 May 2014 - 09:28 AM
I agree with gremlin, doesnt sound sound like the thrust bearing as they tend to whine ...... We mine did anyway.....
Cheers james
Edited by jpw1275, 03 May 2014 - 09:29 AM.
#13 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 03 May 2014 - 09:42 AM
If the noise dissapears when you have your foot on the clutch it will either be ( pretty convinced of this ) the release bearing or idler transfer gear. I had the same problem and it was the idler gear bearing that failed. It started to chew the inside of the transfer case......
Edited by Badboytunes, 03 May 2014 - 09:44 AM.
#14 alex-95
alex-95
  • 6,034 posts
Posted 03 May 2014 - 10:28 AM
Thank you very much guys, Dad did say this morning they make more of a whining noise (like a wheel bearing would make a rumbling noise). We'll have to have alook at it then, Is it a big job to replace it then badboytunes?
#15 Badboytunes
Badboytunes
  • 1,615 posts
Posted 03 May 2014 - 10:45 AM
to be honest.... I entrusted the work to Guessworks ( member on here ) .
I would suspect that it is the clutch release bearing although, as stated, it could be the idler gear/bearing as per my previous posts.
Some say that the clutch canbe changed in-situ but if I were to do it, then I wouls ( as was done tomine ) remove the engine and box for easier access. I also had the gearbox rebuilt at the same time.
