Bolt Hole At Back Of Block?
13 replies to this topic
#1 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 02 May 2014 - 07:09 PM
hi, ive got a 1275 A+ block and there is a bolt hole at the rear of the block (fuel pump side) its about mid way up the block. what is it for?
cheers,
bear.
#2 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 02 May 2014 - 07:50 PM
sure its A plus and no pre A plus
they had a hole at the back in the center about 8mm
#3 sledgehammer
sledgehammer
  • 3,098 posts
Posted 02 May 2014 - 08:15 PM
is it the water jacket drain -
as above should be on the a series don't think they were on the A+
photo would help
Edited by sledgehammer, 02 May 2014 - 08:16 PM.
#4 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 02 May 2014 - 08:23 PM
Mines got the same and it is A+... It's just a water drain bolt.
#5 Ethel
  • 25,943 posts
Posted 02 May 2014 - 09:04 PM
That's the drain plug near the oil pump.
I think Maestros had a stay to support the inlet manifold that bolted somewhere near the fuel pump.
#6 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 02 May 2014 - 11:24 PM
ill get a picture tomorrow, its not near the oil pump its in the centre. a picture will make it easier to understand ;)
#7 NZMini1275
NZMini1275
  • 227 posts
Posted 02 May 2014 - 11:58 PM
My a series 1275 block which was taken from an Austin allegro has an extra bolt hole in centre.  It is tapped but doesn't go through so must of had something bolted there. Im thinking of fitting a knock sensor there and connecting up to a Knocklink warning light.
#8 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 03 May 2014 - 08:41 PM
no engine number.
casting  its 12g1279
also the distributor hole is huge and the retaining bolt hold is at 7-O'clock?
and below is an image of a block with the same dizzy hole. (not the same casting but has the same dizzy hole)
cheers,
bear.
#9 Ethel
  • 25,943 posts
Posted 03 May 2014 - 09:48 PM
It's a pre A. you need one of these to fit the dizzy, as well as the matching drive gear.
Still can't help on the hole, possibly for another model - Allegro.....
#10 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 03 May 2014 - 11:19 PM
thought because of the ribbing it was A+?
#11 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 04 May 2014 - 06:54 AM
No thats def pre A plus
All my pre A plus 1275 blocks are like that with the hole.
#12 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 04 May 2014 - 09:49 AM
ok just to be sure this is a picture of the front of my block, have i got the wrong alternator bracket on then?
0274c5cd-95fd-4ce9-86be-a6b9c80f525f_zps
and have i got the wrong dizzy drive? think this drive is A+?
#13 Gremlin
Gremlin
  • 2,142 posts
Posted 04 May 2014 - 09:54 AM
Yes the alternator bracket is wrong, you need the longer one, and the dizzy drive is wrong as well
#14 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 04 May 2014 - 09:58 AM
cheers guys! :)
