Heater Resistor Pack For Heater -Repair
14 replies to this topic
#1 Realminiman
Realminiman
  • 195 posts
Posted 04 May 2014 - 12:02 AM
so after my mot woes now I have a small problem im trying to solve with speed one on the heater which is the faulty coil thingy .. does anybody have a exact part number of the resistor to buy from maplins or an exact value of it , or a solution.. I did do this a few years back on one of my other mpis but I cant recall what I did !! lol ..
Thank s.. MW
#2 FlyingScot
FlyingScot
  • 2,664 posts
Posted 04 May 2014 - 09:13 AM
Not sure about Maplins but AFAIK it is only about 1.2 ohms but needs to be 120W due to the draw of the heater.
The original is just a coil of resistance wire the air flow helping with cooling.
FS
#3 Realminiman
Realminiman
  • 195 posts
Posted 04 May 2014 - 10:53 AM
ok thanks.. maplins don't go up to 120.. max they do is 10 w..  whatever I repaired the last one with was from maplins
#4 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 04 May 2014 - 11:31 AM
Heere!!
http://mgroverpartfi...t=2&Price=empty
#5 Realminiman
Realminiman
  • 195 posts
Posted 04 May 2014 - 11:08 PM
ok thanks! try on tues..
#6 Realminiman
Realminiman
  • 195 posts
Posted 06 May 2014 - 11:09 PM
out of stock .. :mmkay:
#7 Realminiman
Realminiman
  • 195 posts
Posted 07 May 2014 - 06:34 PM
anybody any solutions ..?
#8 FlyingScot
FlyingScot
  • 2,664 posts
Posted 07 May 2014 - 08:49 PM
The original resistor is an open coil type so you could try this http://www.ebay.co.u...=item1e89f7de12
Going to try it myself as this is becoming an issue.
You could also wind your own from resistance wire.
FS
#9 cambiker71
cambiker71
  • 1,050 posts
  • Local Club: Cambscustomclassics.com
Posted 07 May 2014 - 09:00 PM
I used one of these and soldered the resistor into a seperate circuit on a twin speed switch to convert a single speed to twin...
resistor
http://www.ebay.co.u...=item2c80493fe9
switch(s) for the single speed owners who want to convert :D
http://www.ebay.co.u...=item51acd0b90a
#10 FlyingScot
FlyingScot
  • 2,664 posts
Posted 07 May 2014 - 09:57 PM
resistor
Switch looks okay but I cannot agree with the resistors as they are 10W spec so even with 6 it is still 60W max against 120W needed.
FS
Edited by FlyingScot, 07 May 2014 - 09:58 PM.
#11 cambiker71
cambiker71
  • 1,050 posts
Posted 07 May 2014 - 10:12 PM
They've been fitted for two years now with no problems, and longer than that on my previous daily driver, maybe mpi heaters take a higher load than earlier ones?
No idea what the rover/honda heaters (that these resistors are for) need but modern heater motors are usually much more powerful than mini ones!
#12 Realminiman
Realminiman
  • 195 posts
Posted 07 May 2014 - 10:44 PM
FS
yes I have seen these.. the longer thinner one looks like it could be a straight replacement.. for £7 its worth the gamble and a try ..
#13 Realminiman
Realminiman
  • 195 posts
Posted 07 May 2014 - 10:47 PM
resistor
http://www.ebay.co.u...tem51acd0b90ahi thanks yes ive seen these also.. how do you keep them cool as they are obviously to big to fit into the motor housing?
#14 cambiker71
cambiker71
  • 1,050 posts
Posted 08 May 2014 - 06:51 AM
resistor
I made a bracket from a scrap bit of aluminium, it hangs from the bottom of the heater at the back on The left hand side beside the round ribbed vent.
It's been fine and I leave mine on the slow resisted speed pretty much all the time.
#15 Realminiman
Realminiman
  • 195 posts
Posted 08 May 2014 - 12:29 PM
ok and you used that part with no alterations.. be great if you put up a picture.. ; ]]
