Hello all,
Got a problem at the minute with spraying my drivers wing. Ive been using celly for quite a few years now and always get a decent shine straight from the gun but not this time.
Few months ago I brought some more paint to do the drivers wing (only 1/2 litre). I usually thin the paint 50/50 with thinners first, then add more thinners (70/30) afterwards for the final top coats to get the shine. But this time no matter how much thinners I add the paints drying dull or a sort of matt finish. The weathers conditions have been perfect with perfect temps.
Ive sprayed this wing twice now both with the same effect. I did at first use standard thinners but then switched to anti-bloom thinners which made no difference. Could it be a problem with the paint? When I mix it up in the tin it seems visually to have a slight texture to it?
Any ideas or advice would be appreciated as I haven't got a clue whats going on.
Thanks.
