Help I Need To Get Rid Of Brake Squeal
16 replies to this topic
#1 lyesryan
lyesryan
  • 110 posts
Posted 06 May 2014 - 06:24 AM
Ok so basically when I first get the mini out for a drive its fine but after 5 mins or so it will start squealing as I come to a stop when applying the brakes but if I apply them at high speed they are fine any ideas why this is and how I stop it.
#2 Gremlin
Gremlin
  • 2,142 posts
Posted 06 May 2014 - 06:26 AM
Are the brakes working ok? (Actually stopping you as good as they were) How old is the fluid? What is the condition of the disks, pads, drums and shoes?
#3 lyesryan
lyesryan
  • 110 posts
Posted 06 May 2014 - 06:38 AM
Im not to sure how good they were before because I bought the car stripped it out and rebuilt it without driving it fluid is new shoes are new pads were replaced just before the rebuild but still the same discs and the squeal is only from the front.
#4 timmy850
timmy850
  • 3,387 posts
  • Local Club: MITG
Posted 06 May 2014 - 06:45 AM
Have the pads been bedded in?
#5 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 06 May 2014 - 07:01 AM
I saw this question asked once a few years ago on a different forum, and someone honestly suggested putting a few dabs of grease on the pads to prevent it !
^^^Don't do this^^^
#6 Stevie W
Stevie W
  • 1,204 posts
  • Local Club: P&SMOC
Posted 06 May 2014 - 07:18 AM
Hi,
I believe a product called "copper ease" is applied to the piston side of the brake pads. This is a very high temperature copper loaded compound which helps dampen the high frequency squealing noise you are hearing.
Use sparingly and don't get any near the pad surfaces!
Years ago cars came fitted with anti- squeal shims to stop this noise!
Cheers, Steve.
#7 Gadgets
Gadgets
  • 471 posts
Posted 06 May 2014 - 08:06 AM
Like Steve says the front pads need shimming.
#8 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 06 May 2014 - 09:13 AM
Shim the pads but also use copper grease on the pad to caliper surfaces( make sure you dont get grease on the pad wear surfaces!!)
#9 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 06 May 2014 - 09:30 AM
i would give everything a clean and inspection
refit with a dab of copper grease on the back
#10 lyesryan
lyesryan
  • 110 posts
Posted 06 May 2014 - 03:47 PM
#11 Gremlin
Gremlin
  • 2,142 posts
Posted 06 May 2014 - 03:56 PM
As long as you are happy with the performance of the brakes and everything is sound (mind the pun) don't worry about the squeal, Mintex M1144 pads tend to be squeaky at low speeds as I know but ok at high, if you insist on getting rid of the squeak it might jut be a case of changing the pads, but the M1144'd are excellent pads
#12 lyesryan
lyesryan
  • 110 posts
Posted 06 May 2014 - 08:05 PM
Its just quite irritating and annoying at times if im honest haha
#13 Gremlin
Gremlin
  • 2,142 posts
Posted 06 May 2014 - 08:15 PM
Yeah, what pads have you got?
#14 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 06 May 2014 - 10:11 PM
Mintex do something called Ceratec which is a bit more glue-like than copper grease. Just used it on my Alfa but haven't bedded pads in fully yet to test properly.
#15 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 07 May 2014 - 03:05 AM
There used to be another product from Ferodo I think that formed a compliant bed between the pad and piston to stop the pad vibrating -
Try bevelling the leading edge of the pad and also ensure you run the pads in properly.
