Carb Bulkhead Mod?
7 replies to this topic
#1 TheHippo
TheHippo
  • 159 posts
Posted 06 May 2014 - 05:09 PM
Hi,
I am going to be fitting a pair of twin HS2s and am just wondering if I'm going to need to do any modifications to the bulkhead in order to do so.
Hope someone can help, and thanks in advance.
Dan
TheHippo
#2 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 06 May 2014 - 05:25 PM
dont think you need any mods, didnt some coopers come with em?
#3 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 06 May 2014 - 06:06 PM
No you dont need mods, only webers need them!
#4 carbon
carbon
  • 2,590 posts
Posted 06 May 2014 - 06:23 PM
If you use the correct mini manifold the HS2 carbs will clear the bulkhead.
If you have a Midget or 1100/1300 twin HS2 manifold (and there are quite a lot of these about) the angles are different and they may not clear.
#5 SomethingNew71
SomethingNew71
  • 462 posts
  • Local Club: Carolinas Classic Minis United
Posted 06 May 2014 - 06:26 PM
I had to change my manifold off my Austin America.  Stupid thing was at a 15 degree angle instead of 30 degree.  30 is what you want.  Other than that you shouldn't have any clearance problems.
#6 TheHippo
TheHippo
  • 159 posts
Posted 06 May 2014 - 06:34 PM
I am reasonably confident they have the correct manifold, so it seems I should be ok.
Do I need a 30 degree float angler then? I'm going to be rebuilding them before fitting (although they're in really good condition) so want to get them right before they go on so I don't have to take them off to rebuilt in a few month time...
Thanks for your replies.
#7 SomethingNew71
SomethingNew71
  • 462 posts
Posted 06 May 2014 - 07:07 PM
Yeah I would get the proper float angler as well.  They aren't expensive and its worth throwing on there.  If they are working I don't know that I would do a full rebuild.  The are such a pain if they fall out of sync.  If they came off a mini though you probably don't need the anglers.
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 06 May 2014 - 07:48 PM
Why twins SU have syndrom of going out of tune is because the carbs that do that are worn out and need rebuilding, when done all the problems of a diffferent idle every time you stop disapper
