hello again,
right clutch has been bled up and has has new master and slave cylinders and also pipe & flexi. ive built an engine (first pre verto) and ive bled the clutch up and fitted a new clutch plate but not the diaphragm. also new bearing and plunger etc have been stripped, inspected and greased.
the reason i have used an "old" diaphragm is that it was fitted to a flywheel that i bought and was more or less new and was a "orange" diaphragm.
now my problem,
when i bled the clutch up (without setting stop adjustment) the pedal felt ok, it would go all the way down and return back.
I set the stop adjustment by removing the spring and pulling the clutch arm towards the inner wing (pulled out pretty far) then winding out the bolt to 0.020" freeplay. then i reattached the spring and when you press the clutch pedal it's ROCK SOLID. something that raised a concern was how far i could pull out the arm until "contact" so is the slave just "bottoming out"?
here is a pic to show how far the stop bolt is set
cheers,
bear.
