Bloody Pre Verto Clutch!
19 replies to this topic
#16 Stevie W
Stevie W
  • 1,204 posts
  • Local Club: P&SMOC
Posted 06 May 2014 - 09:12 PM
One is a genuine Rover plunger and the other is a Minispares non-genuine version.
Both are correct for the pre-verto clutch set-up.
Cheers, Steve.
#17 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 06 May 2014 - 09:19 PM
One has the type with a clip for the releae bearing and the other is plain shaft
#18 brad-the-bear
brad-the-bear
  • 1,114 posts
cheers guys :)
#19 Earwax
Earwax
  • 577 posts
Posted 06 May 2014 - 09:37 PM
If in the build you lapped the flywheel to the crank, with wok off check that the flywheel hasn't crept up the taper causing contact with the housing around the thrust bearing
#20 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 06 May 2014 - 09:41 PM
will do
