Air Bubbles Coming From Head Studs
Posted 09 May 2014 - 06:19 PM
Is this likely to be a head gasket?
1293 with new head studs and nuts
Posted 09 May 2014 - 06:44 PM
Just been built with new head gasket?
Posted 09 May 2014 - 06:45 PM
Posted 09 May 2014 - 06:48 PM
Indicates compression leaking from the gasket to the stud holes by the look of it, what gasket did you use? Payen BK450 is the one to use, and if uprated studs/nuts what was the torque the supplier gave you to use. have you given the gasket a heat cycle and then re-torqued it?
Posted 09 May 2014 - 06:56 PM
Use two seperate copper gaskets and they both leaked, real pain in the bum,
They did seal after awhile though
Posted 09 May 2014 - 07:05 PM
Posted 09 May 2014 - 07:32 PM
50ft/lbs with dry studs, and your backing the stud off and then re-torquing? the blocks been checked with a straight edge and the head?
Posted 09 May 2014 - 07:34 PM
Snapon straight edge was used all over block and head before re-fitting and both surfaces def flat
Posted 09 May 2014 - 07:40 PM
Posted 09 May 2014 - 07:43 PM
Posted 09 May 2014 - 07:44 PM
Posted 09 May 2014 - 07:48 PM
Give it a good run then re torque it,
If it still leaks don't worry mine did for awhile then just sealed itself
Posted 10 May 2014 - 04:16 PM
