Spot And Fog Lights, What Order?
Best Answer RedRallyMini , 10 May 2014 - 10:37 PM
What?! No! Spots in the middle and fogs on the outside and pointed a bit outwards like Cooperman says, every rally car with the 4 lights next to each other has that setup.
Go to the full post
14 replies to this topic
#1 Carlos W
Carlos W
  • 10,114 posts
Posted 10 May 2014 - 09:56 PM
I'm fitting spot and fog lights to the front of my mini, do the 2 spot lights go in the middle with a fog light either side or the other way around?
#2 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 10 May 2014 - 09:57 PM
I'm fairly sure the two fogs go in the middle and and the two spots on the outside.
#3 Kieranlee999
Kieranlee999
  • 1,401 posts
fogs in the middle driving on the outside :) that's what ive been told
#4 Carlos W
Carlos W
  • 10,114 posts
Posted 10 May 2014 - 10:00 PM
Cheers guys!
#5 Cooperman
  • 23,323 posts
Posted 10 May 2014 - 10:24 PM
On the rally cars which had 4 lights across the front we usually had the driving lights in the centre and the fogs, angled out to 'see around the corners', at each end of the lamp bar.
We get so little fog these days that there seems little point in fitting fog lights.
In truth it is better to fit a really good pair of driving lights to increase the range of the headlights to help with night driving.
#6 Carlos W
Carlos W
  • 10,114 posts
Posted 10 May 2014 - 10:35 PM
To be honest Peter, the car will very rarely get driven in the dark never mind in fog (although we do get quite a bit of fog in this area of Kent) Dare I say it, I'm fitting them for aesthetic reasons
#7 RedRallyMini
RedRallyMini
  • 309 posts
Posted 10 May 2014 - 10:37 PM   Best Answer
#8 Cooperman
  • 23,323 posts
Posted 10 May 2014 - 10:38 PM
It doesn't really mater in which positions then.
#9 Carlos W
Carlos W
  • 10,114 posts
Posted 10 May 2014 - 10:41 PM
I may decide to take it to work on a foggy day in September.
And as I can see this from my house, it needs to be right
http://www.bbc.co.uk...d-kent-25808048
#10 Ethel
  • 26,055 posts
Posted 10 May 2014 - 11:00 PM
Fogs are less effective if you leave the headlights on, and to be used without headlights they have to be close (16 inches) to the sides of the vehicle.
#11 HarrysMini
HarrysMini
  • 3,352 posts
Posted 10 May 2014 - 11:14 PM
Well I know Rover put the fogs in the middle on their cars with four auxiliary lights. At least the ones I have seen have been that way.
#12 ucchockey
ucchockey
  • 158 posts
Posted 10 May 2014 - 11:31 PM
Do they need proper alignment for mot? My spots come on with beam. Is that likely to fail mot?
#13 Ethel
  • 26,055 posts
Posted 11 May 2014 - 12:36 AM
They must dip with main beam, otherwise they're not tested.
#14 ucchockey
ucchockey
  • 158 posts
Posted 11 May 2014 - 11:08 PM
They only come on if I flash the lights or put lights on full beam.
#15 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 12 May 2014 - 10:41 AM
Fogs on a classic mini are pretty much ineffective anyway, because of the position they are mounted in. In order to be effective in the fog, they need to be mounted much lower down and at the edges of the car (as they are on modern vehicles). You'd be better to do away with them as fogs and have them as four spot/driving lamps instead, that are wired to come on with main beam. That way at least they'd give you better headlight visibility in the dark, as opposed to being little more than decorative as fogs.
