Can You Fit A Vacuum Advanced To A Dizzy?
4 replies to this topic
#1 Dusky
Dusky
  • 5,322 posts
Posted 11 May 2014 - 05:42 PM
Hey, a little question :
you can buy dizzy's online without a vacuum advance (they usually blank the hole where the vacuum pump sits)
can you fit a vacuum pump to it? Is it as easy as just putting your old one on it? Or is it more complex?
grtz!
#2 Dr s
Dr s
  • 428 posts
Posted 11 May 2014 - 05:56 PM
Little more complex.. Typically a dizzy has a set mechanical advance curve and a vacuum curve.
You can buy one that has a given curve and add a vacuum but that might not be what you engine needs.
Perhaps another question about what you set up needs?
#3 Dr s
Dr s
  • 428 posts
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 11 May 2014 - 10:38 PM
Distributors that are available online without Vacuum Advance Units are not really suitable for any car thats driven on the road, the reasons for this are that while on a light throttle thee mixture will be leaner than under power and a weak mixture needs more advance, The effects of a road car without Vacuum Advance will be a loss of MPG and a reduction of torque and driveability. If you have a distributor without one, give the Distributor Doctor a ring he will have vacuum units
#5 Ethel
  • 26,057 posts
Posted 11 May 2014 - 11:33 PM
The centrifugal advance works on the spindle to advance/retard the cam that opens the points. Vacuum advance moves the baseplate that the points are screwed to. If you have, or can fit, a moving baseplate you can have vac advance.
