Help With Floor/sill/inner Wing Alignment
18 replies to this topic
#1 thetrev.com
thetrev.com
  • Just Joined
  • 84 posts
Posted 11 May 2014 - 06:54 PM
Hi
I have fitted a new inner wing (Heritage) and also a complete floor pan will sills attached.
the problem I have is the outer sill does not meet the inner wing. the inner wing fitted ok the door hinge holes matched up also with suspension mounts, the outer lip was ok but now with the floor in this is the result, the floor was fitted using a rear jig and measurements and is in the same place as the old one
the drivers side I did a inner wing repair (Magnum panel ) and this is still out, by about the same. the floor fitted to the old door steps fine level both sides not sure what to do.
any advise or photos of the area being repaired
thanks
trev
Edited by thetrev.com, 11 May 2014 - 06:54 PM.
#2 DANTOO
DANTOO
  • 290 posts
Posted 11 May 2014 - 07:25 PM
Is the sill original or also new?
#3 thetrev.com
thetrev.com
  • Just Joined
  • 84 posts
Posted 11 May 2014 - 07:47 PM
The sill is original they come fitted to the floor
http://www.minispare.../ADA36002E.aspx
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,064 posts
  • Name: Neil
Posted 11 May 2014 - 07:53 PM
Something is definitely amiss there. Was the floor a complete one piece replacement including crossmember??
#5 thetrev.com
thetrev.com
  • Just Joined
  • 84 posts
Posted 11 May 2014 - 07:59 PM
yes the floor was
#6 sonikk4
sonikk4
  • 16,064 posts
  • Name: Neil
Posted 11 May 2014 - 08:01 PM
How does the inner sill line up with the bottom of the A pillar on the inside of the car????
#7 thetrev.com
thetrev.com
  • Just Joined
  • 84 posts
Posted 11 May 2014 - 08:10 PM
The inners are spot on there and also along the door step.
the floor went in too straight forward looking back now.
#8 sonikk4
sonikk4
  • 16,064 posts
  • Name: Neil
Posted 11 May 2014 - 08:26 PM
Have those door steps been replaced in the past??
Other than that Trev i'm a bit stumped as to what is the route cause of your problem. To me it does appear that the door step could be the issue and the outer sill.
You may have to take the outer sill off along with the slinging bracket and jacking point. Then realign everything.
#9 thetrev.com
thetrev.com
  • Just Joined
  • 84 posts
Posted 11 May 2014 - 08:38 PM
Door Steps were original only changing now as in first pic, the original door steps and rear quarter lips all lined up ok. . glad someone else is stumped. would be gutting to take off sills after taking the option to buy complete instead of parts.
#10 sonikk4
sonikk4
  • 16,064 posts
  • Name: Neil
Posted 11 May 2014 - 08:42 PM
Now the other issue could be the inner wing. Can you take some measurements of the bottom hinge holes to the edge of the A panel mounting flange. I will be up my workshop tomorrow and can take some measurements off an unmolested inner wing.
#11 thetrev.com
thetrev.com
  • Just Joined
  • 84 posts
Posted 11 May 2014 - 08:52 PM
will do may be a couple of days before I can get to the lockup.
Trev
#12 henri1972
henri1972
  • 277 posts
Posted 12 May 2014 - 12:21 PM
it looks like your inner wing is out of alinement my steps sit behind the a panel lip on the middle flat lip have you tried a door on it that should tell you where it is wrong hope this helps
#13 sonikk4
sonikk4
  • 16,064 posts
  • Name: Neil
Posted 12 May 2014 - 05:10 PM
Bare with me and i will post some pictures with measurements shortly.
Ok in this picture the measurement is the centre of the holes to the A panel flange return
and in this one the distance is the edge of the A panel return flange to the inner sill. The cut line is where the inner sill is positioned.
#14 thetrev.com
thetrev.com
  • Just Joined
  • 84 posts
Posted 13 May 2014 - 07:13 PM
thanks will get the tape out when up the Garage on Thursday
#15 Minidarren83
Minidarren83
  • 1,207 posts
Posted 13 May 2014 - 09:59 PM
It looks like your problem is the inner wings the hinge holes in new panels can not be used as a reference point for placement. Did you have your old floor in place when the inner wings / repairs were done or did you just cut out all the rot?
