Posted 12 May 2014 - 06:36 PM
Posted 12 May 2014 - 08:37 PM
With a 3.65:1 FDR at 70 mph it will be pulling about 4500 rpm, which is not really high for a 998.
If you fit a higher FDR you will lose a lot of acceleration and may well find that the maximum speed is less due to the inability of the engine to get to peak power in top gear.
The original 998 Cooper used a 3.76:1 FDR.
Posted 12 May 2014 - 09:57 PM
The standard 998 in my City-E had a 3.1 fd and it cruised nicely at motorway speeds with reasonable acceleration, though you did need to drop to third to really get a move on.
Now the engine is mildy modified it cruises very nicely at "motorway speeds" and had decent acceleration.
Although the very late 998 HLE cars had a 2.9 fitted, they had a super-low first gear and different intermediate ratios to compensate, so i wouldn't advise going any longer than a 3.1 fd.
Mini Technical Sections →
Problems, Questions and Technical →
What Size Are These Main And Big End Bearings?Started by scottyboy805 , 19 Jul 2025 ![]() |
engine
Spi Bad Idle And 'tapping' Engine SoundStarted by Simmi Westo , 15 Jul 2025 ![]() |
![]() Help! Water In Oil Question....Started by TerryLee , 06 Jul 2025 ![]() |
Rebuilt Engine Wont Crank With CompressionStarted by Kernreuben , 04 Jul 2025 ![]() |
1966 Mini S - Clutch IssuesStarted by MBradbury73 , 01 Jul 2025 ![]() |
