1989 Sky To Mkiii Cooper(Ish)
13 replies to this topic
#1 jridge
jridge
  • 21 posts
Posted 13 May 2014 - 02:09 PM
I have owned this car since I passed my test in 1997. It was originally a 'Sky' edition, but the powder blue roof and cloud graphic wasn't cool enough to be driving to college in so the roof was resprayed and following a gearbox problem, the engine was swapped for a 1310 built by my Dad with my assistance.
Anyway, I stopped driving it in 2002 when I got a Porsche 944. I forgot all about the mini and it just sat decomposing in my parent's back garden.
In 2012, we got it into the garage and started stripping it down to assess the damage.
0842244A-80C1-498B-9548-8FB5E5405179_zps
We did nothing more until last month when we decided to save it. I started working my way around the body starting with the os front.
My plan is to get the body sound, spray myself in old english white cellulose with a black roof and create a sort of MK3 Cooper lookalike inside and out, but with 12 inch wheels as I like those.
I cut out and replaced rot behind the shock absorber mount.
61A07716-74E1-4898-9447-3FEAD4178DBA_zps
D1C3750D-278B-48EB-A95D-39FBEF9FE7E3_zps
Then a section of the inner wing where it meets the scuttle.
And yesterday, I fitted a flitch repair panel. Welds not ground down or tidied yet.
Next is to replace the top part of the flitch and then block the dash vent hole as I won't be needing it.
#2 Shawbags
Shawbags
  • 159 posts
Posted 13 May 2014 - 02:26 PM
Hi there , keep up the hard work , can you tell me what the idea of blocking the vent hole up is , Shawbags.
#3 jridge
jridge
  • 21 posts
Posted 13 May 2014 - 05:26 PM
It's always seemed to be an extra place for water and crap to get inside the car and when i removed the old plastic mount from the wheel arch, loads of trapped road crud had collected and was causing the worst rust. Unless I was bombing along the motorway, they never seemed to offer much of a breeze anyway. The older cars never had them and I just prefer the more uncluttered look of the dash too. Plus the binnacles always loosened and started vibrating!
#4 jridge
jridge
  • 21 posts
Posted 13 May 2014 - 05:46 PM
Some more horrors......rear valance......
A6ED174B-A948-4241-B8A3-2CB236EE5C46_zps
#5 jridge
jridge
  • 21 posts
Posted 13 May 2014 - 05:48 PM
NS rear window to gutter...
#6 jridge
jridge
  • 21 posts
Posted 13 May 2014 - 05:50 PM
And below where the window meets the waist stiffener.
#7 miniboy1993
miniboy1993
  • 274 posts
Posted 13 May 2014 - 06:15 PM
Got any pics on how it used to look mate ??
#8 jridge
jridge
  • 21 posts
Posted 13 May 2014 - 06:24 PM
got pics somewhere...It was a basic mini sky but I'd only sprayed the roof dark blue and the plastic hubcaps silver. I liked they way it looked like nothing special - back in the day it would beat my college mate's Fiat Uno turbo and keep up with my Dad's Peugeot 205 GTi 1.9 with it's 1310, Piper fast road cam, lightened flywheel and LCB exhaust.
#9 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 14 May 2014 - 07:27 AM
loads of rot to play with!
Have fun...  =]
Ben
#10 jridge
jridge
  • 21 posts
Posted 14 May 2014 - 06:05 PM
Thanks Ben.
Not much today. Made up and welded on top section of flitch after treating metal behind with kurust and zinc primer.
Then welded in a circular patch in the air vent hole.
And then seam sealed it all. Not too pretty, but I didn't want too grind too much off as it needs to be strong.
#11 jridge
jridge
  • 21 posts
Posted 14 May 2014 - 07:11 PM
This is the kind of look I think I'm going for in the end - minus the bonnet buckle and with 12's instead of 10's...
#12 jridge
jridge
  • 21 posts
Posted 12 July 2014 - 09:23 PM
Both flitch panels replaced, shock absorber mounts repaired and front edges of inner wings rebuilt.  Bulkhead taken back to bare metal.
5CA28FF8-15D6-40EB-B68B-D5408B58CA68_zps
...and then etch primed.
A1C4E20B-EB6D-4CFC-84A2-92E1251650D7_zps
Now rolled over onto the less rotted side to tackle the inner/outer sills and door step.
B1EC4E99-0500-4E35-A75E-FE20E82F1E96_zps
A75A8CE7-7566-4FC4-B600-8092F84EC56B_zps
Door step replaced after a bit of bracing. I'm not sure if this was enough to correctly brace, but figured once the doorstep was solid, that would hold everything together while the floor was out. I took measurements from the bar to the doorstep to make sure it stayed the same and it seems to have, so far...
4A134AD0-C438-45C7-BF8B-2AF4D2872C1B_zps
Then made a kind of jig from dexion and a couple of plates on the car, before checking it lined up with the old subframe mounts. I'm hoping I can use this to bolt the heelboard end repair panel to before attaching to the other end and welding in place.
A6A7F79E-215F-4DE8-ACEC-AE2ABBD5A647_zps
Made up a repair for the end of the crossmember where it meets the inner sill. A bit wobbly, but a skim of filler might help. I was planning on fully carpeting it anyway...
8347B2DB-96E2-4964-8255-A695C236C440_zps
Replaced the n/s rear floor under the axle stand mount where it had gone through. Also chucked some paint into the door bin and any places that I wont be able to access with the inner sill on.
08C2F6C2-1D67-420D-9F6C-28AA2E93F778_zps
...and today started to weld the inner sill in. I was going to butt weld, but the more I read, I decided to fully seam weld on both sides of a joddled edge. There shouldnt be any moisture getting between the two as I'll be covering it with seam sealer. I made up a stiffener panel for the inner wing too.
CB4B460D-6B34-4955-B133-EB0D4CB4A3B5_zps
Next, I'll finish off the spotwelds to the door step and replacing the missing bit of floor pan at the front.
It feels much better to have some metal in - it's quite amazing how heavy the scrap metal bin is now!
#13 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 July 2014 - 11:18 AM
Good going!
#14 jridge
jridge
  • 21 posts
Posted 18 July 2014 - 08:53 PM
Only a small update.
Spot welded the step to the inner sill...
8DA6AD7C-2735-4C9E-B4E7-1E78424611BD_zps
I've left the crossmember to inner sill spot welds until the car is the right way up again.
4153FE50-18EA-402B-BD57-971F5A44B2AA_zps
Replaced the removed section of n/s floor from part of a whole pan and seam sealed. I might try and make this a bit neater, but it might not stand out too much under the stonechip. I didn't want to remove too much weld.
17A2A5D2-BA18-4F84-9348-8A86535AC268_zps
Before I replace the heelboard end, I'm going to patch up part of the boot floor/seat squab.
895D815B-AD23-4001-8389-D7A34D8AFDF9_zps
Hopefully get some more done in a couple of days. I've now got a proper 9ltr co2/argon bottle for the MIG that my Dad has modified to accept and hold the larger bottle safely. The little bottles from Halfords were starting to get expensive and it was really annoying to have to stop mid-weld to pick up another.
E11B712B-FCB1-49AD-92CC-80E5B118DE74_zps
