How To Remove Bitumen Residue From Floor
10 replies to this topic
#1 Steve8274
Steve8274
  • 580 posts
Posted 13 May 2014 - 04:17 PM
As above really. I have taken the bitumen off the floor panels but it has left some residue where it all hasn't come off.
What's the best way of getting this off? Tried going over it again with hammer and old chisel but it's taken forever to do a small area and it still doesn't get it all.
Thanks in advance
#2 cradley-heathen
cradley-heathen
    Metro-Man
  • 2,481 posts
  • Local Club: spearmint rhino
Posted 13 May 2014 - 04:35 PM
it is a real pain to get it all off, sometimes it comes off very cleanly, sometimes it leaves a real mess!
i think once you have the worst off i seem to remember using thinners to soften it, then wiping it up with rags. i think, i cant remember for sure!
#3 TORZIEnJIM
TORZIEnJIM
  • 683 posts
Posted 13 May 2014 - 04:51 PM
i used heat gun and white spirit i think. took time but came off in the end...
#4 rodandtom
rodandtom
  • 998 posts
Posted 13 May 2014 - 07:07 PM
White spirit will do it. I didn't need to apply heat. Cleaned up lovely.
Rod
#5 keefr22
keefr22
  • 591 posts
Posted 13 May 2014 - 07:13 PM
Heat gun & cellulose thinners has taken it all off ours.
#6 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 13 May 2014 - 07:38 PM
White spirit used here but make sure its a well ventilated area or you get the mother of all headaches as I found out years ago to my cost.
#7 Cooperman
  • 23,340 posts
Posted 13 May 2014 - 09:19 PM
Heat gun and a good scraper, then thinners.
#8 Daz1968
Daz1968
  • 2,058 posts
Posted 13 May 2014 - 09:33 PM
Petrol also works to remove it although not the safest method
#9 Dusky
Dusky
  • 5,322 posts
Posted 13 May 2014 - 09:59 PM
Have an accident with break fluid... It will peel off in a day, and youll only have to wipe it off ..
#10 Steve8274
Steve8274
  • 580 posts
Posted 14 May 2014 - 04:06 PM
Thanks for responses. Tried thinners on it and it didn't really do anything so just been out to get some white spirits to give that a go. Probably won't get any time till weekend tho.
Oh and if doesn't work, I may consider brake fluid but I think I will pass on the petrol.
Once and if it all comes off with the white spirits, do I need to clean it off with anything before I paint on it
Edited by Steve8274, 14 May 2014 - 04:08 PM.
#11 Daz1968
Daz1968
  • 2,058 posts
Posted 14 May 2014 - 05:20 PM
White spirit tends to leave residue so wipe it over with panel wipe after, horrible stuff is underseal never use it myself but taken enough of someone else's off, i also find a good wallpaper scraper works for large flat areas and only a small amount remains, bitumen is petroleum based which is why petrol gets it off, I have used it but only after scraping and just a rag dampened with it to wipe off last bits.
