What's The Difference
Posted 14 May 2014 - 09:18 PM
I know the head cam and pistons are different but what about the rods and crank and block? Are they stronger ??
Posted 14 May 2014 - 09:38 PM
Posted 14 May 2014 - 09:39 PM
Some later turbos apparently had a tuftrided crank shaft but aside from that they are the same as N/A metro engines.
The camshaft isn't an MG one it's jus a bog standard 1275 cam.
Edited by Tupers, 14 May 2014 - 09:40 PM.
Posted 15 May 2014 - 05:51 PM
The early NA MG has a better cam, larger inlet valve and higher compression.
Phil.
Posted 24 May 2014 - 12:40 PM
The Turbo engines differ from the NA MG Metro motor, the exhaust valve stems are 8mm and sodium filled, the pistons have a thicker crown and 12cc dish and the Turbo engine just has the standard camshaft, the 1st motion shaft nose bearing is also larger.
Phil.
Phil would mini spares P21253-60 pistons be suitable
Thanks tony
