998 Rebore
Posted 15 May 2014 - 09:38 PM
I would be very grateful if anyone can tell me -
a) can it be rebored and what is the maximum bore for a 998
b) can the pistons and head be done as well
c) how much will it cost(approx) fo a rebore, skim the block/head and rework the piston and new rings, basically undo the corrosion? Is it practical and is it worth it, or should I just buy a new engine
c) has anyone got any experience of this and can you recommend anyone to do it?
Again, thanks for all the advice it's greatly appreciated.
Posted 15 May 2014 - 09:41 PM
An accurate build will be better than a second hand engine.
How bad is the corrosion? Were the pistons seized?
Posted 15 May 2014 - 10:42 PM
Was yours the cooper engine?
Posted 15 May 2014 - 10:49 PM
Posted 15 May 2014 - 10:50 PM
Posted 15 May 2014 - 10:55 PM
Posted 15 May 2014 - 11:10 PM
You can bore a 998 out by 0.080" and fit new flat top pistons. This gives a capacity of 1060 cc.
Whenever the engine is re-bored it obviously needs all new pistons and the bores are done by the machine shop to suit the pistons provided.
D-top pistons are no longer available in any oversize and with flat tops you will need to measure and calculate for the required compression ratio.
There is no point in buying a 2nd hand unit as you already have a complete engine.
It will probably need a crank re-grind with new big-end & main bearings, new cam bearings, new camshaft and followers, new oil pump, new water pump, new crank thrust bearings, new timing chain, new valves & valve guides and all new gaskets.
Then there is the clutch & transmission to consider.
Posted 16 May 2014 - 12:39 AM
Thanks so much for replies. Very much appreciated.
Posted 16 May 2014 - 06:23 AM
No-one is going to know what's inside without taking the head off, and without the engine work the car isn't going anywhere.
If you accurately measure and build everything, get the compression ratio right, have the head ported, polished and skimmed you will make improvements to how the car performs
Posted 16 May 2014 - 08:01 AM
That could be an option if you don't want to scrap the block?
Posted 16 May 2014 - 11:37 AM
998s will go out as far as 68mm ( about +.135") though that is right on the limit - the equivilent of a 74mm bore on a big block.
+.080 and +.100 are sensibly as big as you need to go, though you almost certainly won't get hold of D-crown pistons any more unless you are lucky, rich or probably both.
You could get the block sleeved back to standard and just re-use your existing pistons with new rings, and while that would very rather expensive you would at least keep the original block and not have to ruin the head by excessively skimming it.
Posted 16 May 2014 - 05:40 PM
Would it be wise to use pistons which have been sitting in a seized engine, even with new rings and sleeved bores?
It's a typical classic car issue where parts are NLA and have been for many years. We all just have to use what is available.
In the 60's the 998 Cooper was used in competition with different pistons from the D-tops and still were Coopers.
Posted 16 May 2014 - 05:44 PM
Posted 16 May 2014 - 05:53 PM
Easy enough to make raised D pistons from flat top. Just need a lathe and mill. It will add about £100 to the cost of the pistons.
But it's not really worth is as the raised D-top was to increase the CR and with a piston with the top milled down to create the D-top, the CR will be too low unless the block is decked by a further amount, or the head machine down to reduce combustion chamber size.
You might as well just use a flat-top piston and skim the head to get the CR correct.
No-one worries about originality to the extent of considering piston part numbers.
In my 1964 Cooper 'S' I run Karl Schmidt pistons, because they are so strong. it is still a Cooper 'S'.
Posted 17 May 2014 - 08:55 AM
Any extra CC you can gain from a raised crown maintains head deck thick ness. That's a plus in my book.
Ac
Edited by ACDodd, 17 May 2014 - 08:57 AM.
