wondering if anyone can help , every morning i go out to my car go to start it and nothing not a sound no light nothing , so i go and jump it off and fires up straight away after letting it charge for a while id turn it off but when i come back half an hour later again there's nothing no sound no lights anything ive put the multimeter on the alternator and that's putting out about 13 volts anyone got anything else ?
Starting Issue
Posted 17 May 2014 - 07:00 PM
Posted 17 May 2014 - 07:22 PM
13v is not enough to charge the battery, the regulator in the alternator is normally 13.7-14.3v if its not making between those voltages at 2000rpm+ its not charging. Do the tests in the FAQs on the charging circuit here http://www.theminifo...ng-basic-tests/
Posted 17 May 2014 - 07:25 PM
thanks will try tomorrow , but would the battery die so quickly ?
Posted 17 May 2014 - 07:41 PM
would the car not even have enough life in the battery even to show a light on the dash ?
Posted 17 May 2014 - 07:47 PM
If its dead flat and not charging then jumping it and let it charge wont charge it, in its current charge rate 13v is way to low, a flat battery with a good charging system takes many miles to fully charge, Once a battery is dead flat then its sulphated and will never give 100% again.
Posted 17 May 2014 - 07:51 PM
by dead flat do you mean 0.0 volts or just low voltage ?
Posted 17 May 2014 - 07:56 PM
You mention no light nothing in the morning so that battery is flat and might have a very small voltage, but if the 12v 2.5w ignition light wont power thats flat Milo
Posted 17 May 2014 - 08:14 PM
so what do you think i should do , go about diagnosing if the alternators at fault ?
Posted 17 May 2014 - 08:51 PM
Posted 17 May 2014 - 10:44 PM
Hang on a minute, running with the battery removed is not good the alternator wont like it, if its not faulty it is now, the method is fully charge the battery let it stand 4hrs test the voltage
12.65v is 100% charged
12.45v is 75%
12.24v is 50%
12.06v is 25%
If you see 12.45v your battery is sulphated and wont be at its best during cold cranking, replacement is immenent
If you see less the battery is heavily sulphated and needs replacement
If you do see 12.65v the battery is now suitable for a load test which a tyre/battery company can do for free
Either way you either come back with a battery which has either passed or a new one.
Install the battery and carry out the alternator tests
Posted 18 May 2014 - 10:00 AM
think there might be a drain on the battery i set my multimeter to 10 ohms removed negative clamp put one end on the clamp and one end on the terminal and its showing around about 7ohms but when i remove second fuse down in fuse board under the bonnet it drops to 0.00 any ideas ?
Posted 18 May 2014 - 01:42 PM
Posted 18 May 2014 - 05:12 PM
The instant you remove the battery the Alternators finished, with no capacitor ( the battery) between the + and - terminals the alternator voltage spikes to around 200v, this is outside the range of most diodes (approx 50v) and the diode pack is blown at best most likely the voltage regulator as well.
Posted 19 May 2014 - 05:55 PM
Posted 19 May 2014 - 06:29 PM
I change batteries with the car running
