Engine Running On 2 Cylinders Can Anyone Help?
Best Answer sonikk4 , 18 May 2014 - 09:35 PM
By doing a compression test you will see if you have sufficient and equal compression across all four pistons. (within 10% of each other is a good sign) Ideally you will be looking for 150 psi + per pot.
If you have no compression on 2 and 3 for example it will not matter if you have a spark and fuel. Without the compression there will be no firing.
Its a basic check and if you don't have a compression tester you can buy them from Halfords etc. Its something to rule out out of your fault diagnosis.
Go to the full post
10 replies to this topic
#1 Bell-nose
Bell-nose
  • 137 posts
Posted 18 May 2014 - 04:29 PM
Hi everyone,
Okay a bit if background
My car is a 1998 Cooper Mpi.
Rebuilt my car from a bare shell and replaced the box clutch and cylinder head fitting all new gaskets and torquing up properly.
New sparks, new leads, air filter oil filter and valve clearances set ( I think)
Set up leads in line with how it was when It came off the car.
Only appear to have two cylinders and I don't know why. I've pulled a lead out at a time and they all are issuing sparks.
Please can anyone suggest done reasons as I'm out of ideas.
Edited by Bell-nose, 18 May 2014 - 05:35 PM.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,089 posts
  • Name: Neil
Posted 18 May 2014 - 04:33 PM
Have you adjusted your tappets correctly??
#3 Bell-nose
Bell-nose
  • 137 posts
Posted 18 May 2014 - 05:31 PM
Hi Sonikk4
Thanks I did set up the valve clearances if that is what you mean?
#4 jamesmpi
jamesmpi
  • 1,940 posts
Posted 18 May 2014 - 07:05 PM
Have you got the ht leads on in the correct order?
#5 sonikk4
sonikk4
  • 16,089 posts
  • Name: Neil
Posted 18 May 2014 - 07:12 PM
Hi Sonikk4
yes that is what i meant, have you done a compression test to rule that out??
#6 Bell-nose
Bell-nose
  • 137 posts
Posted 18 May 2014 - 08:37 PM
Hi Sonikk4
yes, although they don't correspond to the webbing numbers. i set them up the same as they were (which was right when i took them off the car)
#7 Bell-nose
Bell-nose
  • 137 posts
Posted 18 May 2014 - 08:40 PM
Hi Sonikk4
No i haven't can you explain why this would mean the car would run on 2 cylinders? My assumption os that if its not exact this would result in a lumpy idle only?
By the way its worth noting that the head is a brand new old stock fully built head.
Thanks,
D
Thanks,
#8 sonikk4
sonikk4
  • 16,089 posts
  • Name: Neil
Posted 18 May 2014 - 09:35 PM   Best Answer
#9 Yoda
Yoda
  • 1,958 posts
Posted 19 May 2014 - 08:57 AM
I would be double checking that the HT leads are in the right order before trying anything else!
#10 drs
drs
  • 21 posts
Posted 19 May 2014 - 11:49 AM
first check the HT's as above, the Rover workshop manual is wrong and the Haynes is correct.  From memory I think 2 and 3 are wrong in the rover manual, if you used rover workshop manual beware!
I just put my mpi back it only ran on two cyls, turned out to be one cleaned injector was not working, just a thought!
pauls
#11 Bell-nose
Bell-nose
  • 137 posts
Posted 20 May 2014 - 07:59 PM
Checked the vale clearances and 8 and 2 were miles out  >_< we're taking cm's not mm's!
God only knows how that happened all the others were fine.
Any way thanks to all for your support ale always, without you i would not have finish my project :thumbsup:
next stop the MOT bay......... :closed:
