Oil Leaking Out Of Oil Filter
Posted 18 May 2014 - 08:43 PM
Did a oil change and oil filter change today and oil is very slowly dripping out of the oil filter when running ?
I fill the oil filter up which I normally don't do, it says it has full oil on the dipstick ?
I've done it up as tight as I can by hand,
Will it settle out you think or does it need to be on tighter somehow ?
Cheers all :)
Posted 18 May 2014 - 08:46 PM
Posted 18 May 2014 - 09:05 PM
Do it a tad tighter with an oil filter tool and it will probably solve your problem.
Posted 18 May 2014 - 09:08 PM
Posted 19 May 2014 - 12:46 AM
I have a oil chain tool but it's quite lethal but will try tightening it further :)
Will let you know guys and thanks :)
Posted 19 May 2014 - 02:26 AM
Yeah I smeared the rubber of the oil filter and filled it up 3/4,
Put a bit of rag around the filter if you use a chain type.
Posted 19 May 2014 - 07:06 AM
Posted 19 May 2014 - 08:16 AM
Probably a faulty filter as there cheap just change it
Posted 19 May 2014 - 10:52 AM
Posted 19 May 2014 - 01:27 PM
Ok I won't tighten it lol, annoying about the filter, maybe I can try and taking it off and try putting it back on, means I got to drain the oil again lol
Why?
Posted 19 May 2014 - 02:05 PM
Posted 19 May 2014 - 02:32 PM
Posted 19 May 2014 - 02:35 PM
the oil doesn`t sit that high,
you will need to refill a bit, if your unlucky maybe 3/4 of a liter
freaker
Posted 19 May 2014 - 02:50 PM
Just remember smear of oil on the seal and after initial contact about half to 3/4 of a turn should be fine to seal it to the filter housing
