Hi guys need a hand again ,can anyone tell me how to remove this valve as I have tried but don,t want to force it its in a 1275 engine as I have engine in bits at moment and want to check ok
How To Remove Oil Pressure Relief Valve
Posted 19 May 2014 - 07:49 PM
Posted 19 May 2014 - 07:50 PM
undo the cap, then simply fish it out with your fingers.
Posted 19 May 2014 - 07:53 PM
If it turns out that it is stuck, then you need to pull it out by putting a thread down the inside of it... A spark plug tap is the ideal size.
Posted 20 May 2014 - 11:57 AM
As above, try a finger or dowel and if that does not work, take an appropriate large tap and start threading it into the back of the plug. When it catches you can pull the plug out using the tap as a handle.
Posted 20 May 2014 - 07:22 PM
Many thanks guys ,finger wasn,t going to work but carefully inserted a threaded bar in and out she came, just aswell I checked as it was damaged.
Posted 20 May 2014 - 07:25 PM
I have used a pair of needle nose pliers before for this job, pop them inside the valve cylinder and open them so it grips and then pull :) Probably easier than a tap unless yours is really stuck
Posted 04 July 2015 - 05:08 PM
Posted 04 July 2015 - 06:09 PM
Don't think so.
Posted 04 July 2015 - 07:50 PM
I have an internal expanding tool I made from a Dyna Bolt. Simple, and quick.
Posted 04 July 2015 - 08:14 PM
Would it be possible to remove the valve SEAT with the engine in situ without making too much swarf?
Why would you want yo do that?
Why do you think it is damaged?
I think I would be doing a rebuild again.
Posted 04 July 2015 - 09:33 PM
because the relief valve that Came out when i was doing the rebuild was badly scratched ( face of the cup was okay, but the side had 2 20 thou deep scratches, thats why the engine needed a Full rebuild in the first place, broken idler bearing) but I never thought about the.seat inside the Block that could be damaged, so Id want to check that, but its kinda dark in an engine bay..Why would you want yo do that?Would it be possible to remove the valve SEAT with the engine in situ without making too much swarf?
Posted 04 July 2015 - 09:34 PM
Posted 04 July 2015 - 10:01 PM
Your best bet is to buy/beg/borrow/steal a prob camera thing that you can stick on the hole to have a look.
But most damage is caused by using a ball instead of the proper valve. Damage on the side of the valve does not mean that the seat will have damage.
Anyway back to my question why do you want to remove it? You have not really answered it.
If everything is working fine don't play.
Edited by nicklouse, 05 July 2015 - 09:09 AM.
