Hydraulic Handbreak Removal
2 replies to this topic
#1 Cooper1
Cooper1
  • 47 posts
  • Local Club: WSMOC
Posted 19 May 2014 - 09:12 PM
My mini when bought had been fitted with a hydraulic handbreak that A) doesn't lock and B) when used could launch you through the window.how easy is it to fit a cable hand break and as a novice am I right in thinking its two cables,one to each drum?
#2 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 19 May 2014 - 09:16 PM
It depends on the year of the car, pre 76( i think) had twin cables, post 76 were single cable
#3 sledgehammer
sledgehammer
  • 3,129 posts
Posted 19 May 2014 - 09:36 PM
I would look thru this ...
https://www.minispar.../Brakes.aspx?04
I'm guessing at cables - quadrants & pins ,  Compensator Bracket (if later)
I would think the brake has the lever inside the back plate - but without being there its a guess ?
and the cable plates in the floor & handbrake it's self , & back plate gaiter ? & pins
take care when removing the old hydraulic brake , as if it is in the original place it will need the pipes re routing
why not go for a nice new cuprinicle front to rear pipe ?
If you are not sure get someone to fit it , when reworking brakes , it's best to get some who knows
EDIT - after looking at your Avatar - I am guessing it's a early set up
Edited by sledgehammer, 19 May 2014 - 09:39 PM.
