Bitumen
10 replies to this topic
#1 Cooper1
Cooper1
  • 47 posts
  • Local Club: WSMOC
Posted 20 May 2014 - 01:08 PM
When people take up the bitumen do they relay it once done checking the floor pans?
#2 cal844
cal844
  • 9,632 posts
  • Local Club: TFMOC
Posted 20 May 2014 - 01:11 PM
No, it adds way too much weight
#3 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 20 May 2014 - 01:26 PM
You'd find it very hard to relay it as it comes off in chunks.
I would replace it with something more effective, Silent Coat.
If you're not bothered about noise, just leave it bare.
#4 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 20 May 2014 - 05:16 PM
It catches on fire pretty quickly when you start welding the floor. I removed most of mine but left it on the rear seat base; then set fire to it  :shy:
#5 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,053 posts
  • Name: Neil
Posted 20 May 2014 - 05:39 PM
Remove completely (big weight saving) then use a decent sound proofing product of your choice (its what you can afford to fit)
#6 skmulvany
skmulvany
  • 19 posts
Posted 21 May 2014 - 05:41 PM
Hi, I removed the bitumen on my mini, and was wondering what would be good for removin the residue bitumen?
#7 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 21 May 2014 - 05:51 PM
Having tried to sound proof a mini in the past, I wouldn't bother now. Its a pain, costs money and goes from loud to slightly less loud.
#8 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 22 May 2014 - 04:33 PM
Spraying on liberal coats of stonechip on my new floor (both sides) hopefully this will shush things down a bit. Quick to apply, looks good and hides a multitude of sins. If it dosent reduce road noise then I'll simply turn up the metallica! ;0)
#9 Marco1972
Marco1972
  • 822 posts
Posted 22 May 2014 - 09:51 PM
Thinners works well or even white spirit or as a last resort petrol ( I'm not recommending it )
Make sure the area your working in is well ventilated
#10 skmulvany
skmulvany
  • 19 posts
Posted 22 May 2014 - 10:44 PM
I tried the white spirit and it worked well. I put a good bit on left for an hour to soak in then got the wire brush on the drill and it comes off.
#11 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 May 2014 - 04:57 AM
I'm going to be replacing mine with something as close to the original stuff as possible.
Don't care about the weight or anything like that, just want it to look factory.
So i guess it's down to personal preference.
Ben
