Are These Headlight Bulbs Legal?
8 replies to this topic
#1 rik_t
rik_t
  • 276 posts
  • Local Club: Robin Hood
Posted 21 May 2014 - 12:12 PM
Just thinking of these for my newly upgraded headlights, are they legal though?
http://www.ebay.co.u...984.m1423.l2649
#2 willava182
willava182
  • 704 posts
Posted 21 May 2014 - 12:31 PM
The law is bases on wattage, I think 55 is the maximum, stuff like this I just saw to do it, then if/when you get pulled over or time for the mot just swap them for ones you know are legal! :)
#3 markl1963
markl1963
  • 13 posts
Posted 21 May 2014 - 01:06 PM
There is no check in the MOT manual for bulbs as such other than to check they are not falling out, MOT manuals are available free here:-
http://www.motinfo.g...tdocs/index.htm
As long as you are not dazzling every-one you should be OK.
#4 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 21 May 2014 - 01:17 PM
No.  LED light is very directional, unlike halogen bulbs.  They need specific lights and these arent available for Minis.  Get yourself some Osram Night-breakers and be done with it.
#5 bikewiz
bikewiz
  • 321 posts
  • Local Club: NEMO
Posted 21 May 2014 - 01:18 PM
Based on the 310 Lumen output they state in the specs I doubt they'll be as bright as a standard H4 55/60 watt which is rated around 700/1200 lumen depending on what source you believe. They will look "whiter" than standard H4 bulbs but not really "brighter"
#6 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 21 May 2014 - 01:26 PM
My polo came with LED sidelights for some reason, and they're very bad. Can't see them until it's really dark, and they don't reflect in the bowls much at all. I would definitely not have them as main driving lights!
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 21 May 2014 - 02:52 PM
They are, but are about £500 per pair.
These lamps aren't legal no, because your headlights are only approved to be used with a filament bulb regardless of the power output. As said the output pattern of these will be all over the place and so they will make a mess of the beam pattern, and I have to agree they probably won't be bright enough.
#8 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 21 May 2014 - 03:16 PM
Use Osram Nightbreakers, they're probably the best bulbs you can get.
Those LEDs, are not only illegal, but are probably very inefficient. They are also very cheap which makes me wonder whether the quality is really up to it.
#9 Mini 360
Mini 360
  • 4,933 posts
Posted 21 May 2014 - 03:27 PM
And ugly as sin
