Weber 40 Squealing At A Certain Throttle Position?
Best Answer KernowCooper , 21 May 2014 - 10:29 PM
The only time I have come across this is on a DCOE where on a light throttle where there is high manifold vacuum, and the noise was air leaking in past the carb to manifold sealing rings (misab Plates), and this was a high pitched squeel. Have you replaced/checked yours are not perrished or incorrectly setup on the mounting washers.
Go to the full post
3 replies to this topic
#1 Ro8bieg
Ro8bieg
  • 1,581 posts
  • Local Club: Fylde Mini Club
Posted 21 May 2014 - 10:07 PM
Basically I have a weber 40 and at a certain throttle position (not RPM) it makes a high pitched constant squeak, annoyingly this happens to be at the position that I cruise in at 30mph anyone any ideas what it could be? Thanks
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 21 May 2014 - 10:29 PM   Best Answer
Edited by KernowCooper, 21 May 2014 - 10:32 PM.
#3 Ro8bieg
Ro8bieg
  • 1,581 posts
Posted 22 May 2014 - 04:36 PM
You sir are a legend! Tightened the 4 bolts down and no more squealing :D
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 22 May 2014 - 04:39 PM
Been there done that ;D Glad your sorted
