Rear Wheel Arch Replacement Help
2 replies to this topic
#1 macauley151
macauley151
  • 75 posts
  • Local Club: Solent mini club
Posted 22 May 2014 - 04:42 PM
I am going to replace the rear wheel arch but I have never replaced a panel on the car before. I am a qualified welder but have not done anything like this before.
what's the best way to replace it?
spot weld the whole thing in?
do I use and sealer?
I honestly don't know what to do to give best possible protection so if someone could give me a guide. this would be much appreciated
thanks, Macauley
#2 Marco1972
Marco1972
  • 822 posts
Posted 22 May 2014 - 05:37 PM
Drill out the spot welds and remove the old panel
Clean up the surface that the new panel will be welded to
I'd add a coat of weld thru primer then ( I assume you will be using a mig ?) drill holes in new panel and plug weld in place
I use etch primer then primer followed by gravi guard stone chip then top coat
Hope this helps
If you look on one of sonics threads you will see he has done this very repair
Good luck
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,076 posts
  • Name: Neil
Posted 22 May 2014 - 06:35 PM
And i'm just about to update this as well.
Is it the whole arch you are replacing or just the outer??
If its the outer section with it installed in the car is a bit awkward. Now personally i would consider removing the whole thing, then you can split it in two, replace the section that's rusty then weld it back in place.
Now the awkward bits to look for are as follows.
Fwd arch close out. Now this is only attached with spot welds but you will need to see them from within the rear arch so clean off any underseal etc.
Then you have the companion bin rear tang, again only spot welded but can be accessed from either in the car or from the wheel well.
Next will be the bulkhead panel that attaches to the inner arch, again spot welded.
Now there is the bump stop bracket in the boot, again this needs to be accessed from with the arch.
And finally the rear subframe reinforcing bracket in the boot.
Everything else can be accessed from within the wheel well.
This is the thread
http://www.theminifo...s-mini-special/
