Metro / Min Turbo Pistons
6 replies to this topic
#1 Waltermini
Waltermini
  • 36 posts
  • Local Club: Na
Posted 24 May 2014 - 11:42 AM
I'm looking for some metro / mini turbo pistons
As I need to rebuild my 1275 and wish to go turbo route
#2 Ethel
  • 25,952 posts
Posted 24 May 2014 - 12:03 PM
You probably don't, both your block and the pistons would have to be in top condition, with little wear, to make them worth fitting - with new rings. Even the standard production pistons will stand some boost, more than Metty Turbo had as standard. Getting a minimal overbore and using 21253's is likely to be your best option, unless you're after extreme horses, in which case there's be a lot more expense than just the pistons.
#3 Waltermini
Waltermini
  • 36 posts
  • Local Club: Na
Posted 24 May 2014 - 12:33 PM
Thanks for that no don't want to go silly power just want a reasonably quick turbo mini till I learn a bit more about how they work etc.
Ps noticed your a tea, member. Quick question, I'm a paid up member is there a link for where I can get discount?
Thanks tony
#4 Ethel
  • 25,952 posts
Posted 24 May 2014 - 01:33 PM
http://www.theminifo...sive-discounts/
Building from the bottom up is always sound practice. Turbos don't need revs to make power, so the reciprocating parts (pistons & rods) aren't as critical, but strapping the centre mains bearing is worthwhile: along with the usual refurbishment. Have an idea of where you want the CR to be so you can buy pistons that won't require a huge amount ground out of the head to get it down. Around 9:1 is practical for a road car, especially with an intercooler. The Metty Turbo was 9.4:1, the same as many other A+'s.
#5 Waltermini
Waltermini
  • 36 posts
  • Local Club: Na
Posted 24 May 2014 - 03:48 PM
Thanks for the link and advice
My thoughts where to rebuild the metro turbo engine
There is a set of P21253-60 for £130 available, unused? (8,4cc)
Leave the metro cam in and lightly flow the head
And run about 5psi
Question is metro t3 or a renault t2?
Cgeers
#6 Waltermini
Waltermini
  • 36 posts
  • Local Club: Na
Posted 24 May 2014 - 03:49 PM
Will also fit centre pick up and x pin diff
#7 Ethel
  • 25,952 posts
Posted 24 May 2014 - 05:40 PM
The gearbox is the weak link, defo upgrade the diff and check everything else over. 5psi is very modest, both T2 & T3 are dated, depends on what manifold you use. A GT17 on a fabricated manifold (such as mirage's) will also save you cutting the bulkhead for clearance. Plenty of info available google turbo-mini
