Thanks Guys
Posted 27 May 2014 - 03:08 PM
Posted 27 May 2014 - 03:19 PM
Ill get some in a moment
Posted 27 May 2014 - 03:25 PM
finger nail test .....if you feel anything then bin it......
Posted 27 May 2014 - 03:40 PM
Mainshaft looks knackered, assuming it is as pitted where the input gear bearing sits
Posted 27 May 2014 - 03:54 PM
The small end of the mainshaft i can feel a small lip
Swear this mini will be the death of me or my bank account.
Posted 27 May 2014 - 04:12 PM
Whats the rest of the box like? Syncro hubs, dog teeth on gears etc. Looks like its been underwater! might be better off starting with a different box in better condition for rebuild.
Edited by minimole23, 27 May 2014 - 04:12 PM.
Posted 27 May 2014 - 04:49 PM
Posted 27 May 2014 - 04:54 PM
Posted 27 May 2014 - 04:55 PM
Posted 27 May 2014 - 05:09 PM
Ill go have a look now since the gear box has been stripped and stored in bags all labeled so ill go find it
Posted 27 May 2014 - 05:24 PM
Ac Dodd Bearing and 1st motion shaft and the shaft inside as well looks same as this shaft, can tell its all no good.
Posted 27 May 2014 - 06:47 PM
Absolutely FUBAR.
I'm afraid with mini gearboxes you tend to open a can of worms. A lot of amateur mechanics shy away from the gearbox but are happy to touch the engine. I often find the gearbox has been left and the engine has been replaced at least once.
Baulk rings, double roller main bearing, lay shaft, main shaft. They're the usual problem areas.
Differential always worth replacing the pin, always
Posted 27 May 2014 - 06:51 PM
