What Size And Thread Pitch Is A Pressure Release Valve Cap
8 replies to this topic
#1 bloke
bloke
  • 139 posts
Posted 27 May 2014 - 07:06 PM
Hi there, pretty much as the title says, I have been measuring the pressure release valve cap with a vernier caliper and thread pitch tool.
I was convinced that this should be Imperial but things don't seem to add up, thread pitch seems to be 1.75 metric but it doesn't sit comfortably in the grooves, the outer diameter is 20.83 millimetres or .819 inches which is approximately 13/16
Unfortunately I have mislaid my Imperial pitch tool which is annoying and all I can find is a Japanese one.
Anyway, any help will be gratefully accepted, yours, Bloke
#2 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 27 May 2014 - 07:15 PM
Are you talking about the oil pressure relief valve on the engine block?
#3 bloke
bloke
  • 139 posts
Posted 28 May 2014 - 06:36 PM
Yes, that's the one, the little cap that stops the spring and the ball bearing falling out. It's exactly the same size and thread as the oil temperature gauge on an MPI, I'm going to drill and tap it so I can fit an alternative temperature sender. But I also want to make up a few and need to know what taps and dies I need, as some of the sensors that I have will be on the limit for what the cap is capable of.
#4 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 30 May 2014 - 01:31 AM
Sorry for the delay in replying.  I was too lazy to remove the oil cap from my car and was looking for a drawing I did several years ago instead.
I last measured the cap in 2006 and found it to be an odd pitch of 13/16" x 14 TPI.
#5 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 30 May 2014 - 02:44 AM
13/16 x 16 would be BSF, not that it's much help here
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 30 May 2014 - 11:24 AM
Hmmm.   Interesting.  The OP (Bloke) said that 1.75mm pitch was close and that would be about 14.5 TPI.  I measured 14 TPI back in 2006.  Bloke also measured the major thread diameter larger than what I found.  It sure would be nice if it were a size/pitch for a common die.
When I measured the cap I was going to make my own adjustable pressure relief valve.  I decided to buy one instead.   Perhaps the easiest thing for the OP to do is buy a relief valve cap and modify it rather than machine one from scratch.  Just a thought.
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 30 May 2014 - 02:36 PM
13/16" x 14 is a non-standard BSP size, and this fitting is parallel threaded. It is available as a tap and a die pretty easily as it was quite common on old pumps and stuff. The non-standard size stops you hooking fixed rigid pipe straight up to the pump and forces you to fit a specific part like a hose adaptor or whatever the pump came with to let it move so it couldn't destroy itself.
#8 bloke
bloke
  • 139 posts
Posted 31 May 2014 - 08:07 PM
Thanks everyone, have done just what dklawson suggested, and just tapped a new thread into the end of a relief valve cap. Had to use some extra washers, otherwise I wouldn't have enough thread for a decent joint, but other than that it all seems to be very sound.
At this stage is just a test fixture, if all goes well and the sensor is a good one, I will investigate machining up something a little bit more substantial.
All the very best, Bloke. :)
#9 DeadSquare
DeadSquare
  • 3,189 posts
Posted 07 June 2018 - 11:27 PM
Much too late to be of any use, but it is 1 / 2" water pipe on a pre A+ block
