Front Wheel Play
7 replies to this topic
#1 graydan
graydan
    Just On Tickover
  • 8 posts
Posted 27 May 2014 - 07:28 PM
Hi everyone,
I am after some advice please. A while back I noticed that I had some play in the front wheel when I moved it at the 12 and 6 o clock positions. Does this mean the wheel bearing has play in it or is it the top ball joint? I can't feel any play in any other positions it only seems to be in the 12 and 6 o clock positions, which is why I thinking it may not be the wheel bearing. Any advice would be much appreciated.
#2 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 27 May 2014 - 07:32 PM
It could be the balljoints, try greasing them, if it reduces or goes away youve found the problem
#3 Alex_B
Alex_B
  • 4,573 posts
Posted 27 May 2014 - 07:35 PM
FYI Greasing them may reduce the play but it shows you need to replace the joints, dont just regrease them and call it fixed!
#4 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 27 May 2014 - 07:40 PM
I did, on both cars, will be replacing them next MOT
#5 graydan
graydan
    Just On Tickover
  • 8 posts
Posted 27 May 2014 - 07:45 PM
Thanks everyone. So by the sounds of it, it's more likely to be the ball joint rather than the wheel bearing?
#6 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 27 May 2014 - 07:47 PM
Yeah, id advise doing both sides ( 2 per side)
Keep the old shims, they are reuseable
#7 Alex_B
Alex_B
  • 4,573 posts
Posted 27 May 2014 - 07:48 PM
Its a play it by ear situation, but safest answer would be to replace which is why I said it :)
#8 graydan
graydan
    Just On Tickover
  • 8 posts
Posted 27 May 2014 - 07:56 PM
That's great. Thanks to everyone for their response, much appreciated.
