Engine Out What Should I Replace On It.
26 replies to this topic
#1 mini-kev
mini-kev
  • 10 posts
Posted 29 May 2014 - 10:27 AM
Hi All
last night i removed my the engine from my 998 so that the shell can go off to be sprayed. while the engine is out im gona give it a good clean and paint will change the water pump and head gasket. but was wondering is there anything else i should do while it is out? im not looking for any performance upgrades just want a nice running 998 with as few oil leaks as possible :-p are there any seals worth replacing?
any advice will be gratefully received.
Regards
Kev
#2 Gremlin
Gremlin
  • 2,142 posts
Posted 29 May 2014 - 10:29 AM
Depends what you want to spend really, ideally a full strip down but funds may not allow this
#3 coopdog
coopdog
  • 4,506 posts
Posted 29 May 2014 - 10:38 AM
dont change the headgasket if you dont need too
#4 mini-kev
mini-kev
  • 10 posts
Posted 29 May 2014 - 10:40 AM
i dont mind spending a couple 100 to get her running nice im planning to keep her for a couple years and then passing over to my son as a first car so want to do it right.
#5 nala56
nala56
  • 36 posts
If it's not broke don't fix it. Lol. But if there are obvious leaks like rod change oil seal nearly always needs changing. Alan
#6 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 29 May 2014 - 11:54 AM
I very much agree with that sentiment :-)
#7 mini-kev
mini-kev
  • 10 posts
Posted 29 May 2014 - 12:29 PM
was going to take the head off to paint and check the condition for the pistons but if thats not worth doing ill leave the head on.
#8 Gremlin
Gremlin
  • 2,142 posts
Posted 29 May 2014 - 03:16 PM
Change the head gasket if you were planning on taking the head off, no matter how many stories you hear about head gaskets not sealing if you do it all right, it wont leak, and use a quality gasket
#9 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 29 May 2014 - 03:43 PM
Would a BK450 do the OP?
#10 Gremlin
Gremlin
  • 2,142 posts
Posted 29 May 2014 - 03:51 PM
Is this a test? The BK450 is a 1275 gasket, I get the Minispares small bore performance fibre gasket, mainly because it quotes the compressed volume and torque stages
#11 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
If it were me I would give it a refresh, New bearings, oil pump, water pump etc. Should keep it going for a few more miles!
#12 coopdog
coopdog
  • 4,506 posts
Posted 29 May 2014 - 03:53 PM
ive found the firbe ones are the only ones i can get to seal,
copper ones are terrible
#13 Gremlin
Gremlin
  • 2,142 posts
Posted 29 May 2014 - 03:59 PM
When I had some cylinder head work done, the valves weren't sealing but I'd already torqued it down, but obviously hadn't got up to temperature or even had coolant in it, I was advised by the engine builder that it would be fine and it was amazingly!
#14 AlexMozza
AlexMozza
  • 1,248 posts
Posted 29 May 2014 - 05:59 PM
Use a sealant with it. A light application of silicone sealant will help. I use it on Aston DB2 engines and works a charm. Allows a bit of give too whilst fitment.
#15 Gremlin
Gremlin
  • 2,142 posts
Posted 29 May 2014 - 07:11 PM
Silicone on your head gasket?! I'm guessing you don't put it near the fire rings?
