Fuel Hose
Posted 29 May 2014 - 09:47 PM
http://www.carbuilde...uel-hose-6mm-14
Cheers,
Ian
Posted 29 May 2014 - 09:51 PM
Posted 29 May 2014 - 09:56 PM
Personally I wouldn't, I'm sure you could sell it to people on here for just as much as you paid, why are you not going to run it inside
I've read that it will whiff of petrol in the car plus safety if it leaks
Posted 29 May 2014 - 10:02 PM
Posted 29 May 2014 - 10:28 PM
It will only wiff of petrol if it leaks, and why would it leak? Just don't have any joins in the carI've read that it will whiff of petrol in the car plus safety if it leaksPersonally I wouldn't, I'm sure you could sell it to people on here for just as much as you paid, why are you not going to run it inside
Posted 30 May 2014 - 01:18 AM
Fuel hose is porous, and fuel vapour can leak through the shell, even if it's in perfect shape. In general, it is recommended to keep hose to a minimum, it's best to run pipe for the long distances. It's more durable, longer lasting, doesn't get eaten by ethanol in fuel, and doesn't let vapour leak out.
Tube for the long runs, hose for the small places where flexibility or bends are needed.
Will that work? Yeah. And you probably won't even notice the vapour since it's outside (it's really a small amount, though you're likely to notice it if inside the car). But it's not the "right" solution…also, the tube is a smaller diameter, so it's less likely to get hit underneath, in the first place.
Posted 30 May 2014 - 03:29 AM
I forget now the legalities of running fuel supplies inside the car, but I wouldn't.
As for hose that you've had for years.....hmmmm
Posted 30 May 2014 - 06:58 AM
Ooooft, overbraid. I wouldn't use it inside the car, or outside too be honest. In fact i dont use it anywhere anymore! Wouldn't even think about it if its been sat around for a few years, it does tend to go brittle and go off, and for the price of a few metres of hose its really not worth it.
Posted 30 May 2014 - 09:01 PM
I'll go for rigid pipe underneath then, most likely kunifer as I've used it on my brake lines.
Out of interest what inside diameter pipe should I be looking at for a fast road 1380, 6mm or 8mm?
Posted 30 May 2014 - 09:04 PM
Posted 03 June 2014 - 10:41 AM
6mm will be plentiful
Cheers!
Is that 6mm outer diameter or inner?
Looked into kunifer pipes and they show 6mm outer = 4.58mm inner after wall thickness taken away
or 8mm outer = 6.58mm inner
The old rubber petrol pipe I had was 6mm inner I think.
Posted 03 June 2014 - 11:35 AM
cheers james
Posted 03 June 2014 - 04:08 PM
