Hi, I have a 1987 Mini Mayfair, I purchased the car which had been sitting static for sometime. The clutch (verto) was non exsistent and found the slave cylinder was knackered so I have replaced it. The clutch now feels as it should but it still won't go into gear with the engine running, it goes through all the gears with engine off.
Could it be an internal problem, thrust bearing like a previous post on the forum?
I am taking the engine out as I am restoring the mini but wanted the mini running ok before incase I needed to change clutch or anything major that would be easier with engine out so wanted to find the problems now, don't want to be changing the clutch etc once I have put the engine back in.
I know its difficult to diagnose from a far but any ideas would be gratefully received.
