In this age of everything computerized I anticipate everyone on this board has their tires computer spin balanced. I am doing a tire change on the cheap and was going to start with a nearly free bubble balance. If I like the results, I'm done. If I'm not happy it's off to find the cheapest garage to spin balance the Mini's 10" wheels.
Has anyone ever done a bubble balance on 10" rims. If so, do you know if the tape-weights will clear the 7.5" disk brake parts on the front wheels? Are there ideal/good locations on the rim for adding the weights? And I know this varies for each wheel/tire combination but how much/many weights have you noticed are typically required for any balancing method? For the record, these are a new set of Yoko A008s and I am mounting them on a set of steel Dunlop (factory style) rims.
Thanks,
