All items below are zero miles and around 1 hours running time. I'm going verto, so it's all surplus to requirements. All you need is a friction plate and it is good to go.
Hi Torque Inertia Starter - Reconditioned Lucas starter with an adaptor plate to fit the mini. Made by a Friend of Wil H. Requires the bottom bolt hole in the transfer case to be drilled out. £100 + £10 P&P
Minispares Ultralight Flywheel as per - www.minispares.com/product/Classic/Clutch/Flywheel/C-AEG620.aspx £110 + £10 P&P - Strap spacers in the pic below
Grey Cover - £25 + £6 P&P as per www.minispares.com/product/Classic/Clutch/Performance/C-AEG482.aspx
MED HD Clutch Arm and plunger, 6 x MED Competition Drive Straps, 2 x standard straps, MED Flywheel Bolt (standard washer), New release bearing and MED EN16T Drive Strap Bolts.
http://www.med-engin...d-hd-clutch-arm
http://www.med-engin...on-drive-straps
http://www.med-engin...bolt-and-washer
http://www.med-engin...ive-strap-bolts
Cost close to £150. Asking £100 + £6 P&P
Aluminium Back Plate - Rear has corroded and I'm not convinced it's 100% flat - £30 plus £10 P&P SOLD AS SEEN.
Edited by apbellamy, 31 May 2014 - 01:16 PM.
