How Long To Strip A Mini Down?
Posted 31 May 2014 - 02:47 PM
Posted 31 May 2014 - 03:06 PM
Posted 31 May 2014 - 03:08 PM
Complete stripdown to shell.... couple of days but double that as for ease of reassembly afterwards lots of bags & tags needed and a seriously organised storage space.....
Cleaning refurbing and replacing duff or broken bits....add a month....... and in however good condition your car is - nuts will shear (e.g thermostat studs, door hinge studs, rear subbie bolts etc...its a mini
Posted 31 May 2014 - 03:28 PM
as the others have said lots of bags and label everything and take lots of photos of how everything goes,makes life so much easier for the rebuild..mine took about 3 days..including running out to buy more/the right tools
Posted 31 May 2014 - 03:33 PM
If I was doing it properly (I literally went like an animal) and labelled or took photos, it would take me a few days as I wouldn't rush.
Spend time now, bag, label and take pictures as it will make your life so so much easier when you come to reassemble.
Posted 31 May 2014 - 03:39 PM
Take photos as well!!
Posted 31 May 2014 - 03:49 PM
Posted 31 May 2014 - 04:41 PM
should take you around half a day to strip it to bare shell.
just chuck all your nuts and bolts in a box, why anyone would do a full shell respray and then rebuild with old fixings always confuses me??
just have a spray around with penetrating fluid (not wd40) a few times a week for a couple of weeks before you strip it. are you doing it in ellesmereport?
Posted 31 May 2014 - 04:54 PM
To keep things simple. I can't think on anything more mind boggling than trying to work out what type of hardness, thread type and length for all nuts and bolts on the car.
Posted 31 May 2014 - 05:44 PM
Good tip thanks.
Posted 31 May 2014 - 06:08 PM
These are usually the cars sold as unfinished projects, what about window winder screws bolts etc, dash board, fixings etc, screws for, various trim, all the under bonnet bolts that can be reused.should take you around half a day to strip it to bare shell.
If I was looking to buy a project and was given a bucket of unlabelled fixings it would need to be cheap or only for breaking.
Photo, small bags, label, hand made diagrams for wiring connections etc, leave large sections together if possible and refurb them as one unit rather than lots of half finished jobs.
Posted 31 May 2014 - 06:31 PM
To keep things simple. I can't think on anything more mind boggling than trying to work out what type of hardness, thread type and length for all nuts and bolts on the car.just chuck all your nuts and bolts in a box, why anyone would do a full shell respray and then rebuild with old fixings always confuses me??
Can you buy a full nut n bolt kit for minis? I'm sure you can for some old VW's
Posted 31 May 2014 - 06:37 PM
Edited by CityEPete, 31 May 2014 - 06:39 PM.
Posted 31 May 2014 - 06:46 PM
it's a mini, how many nuts and bolts do you think there are on the whole car?? i seriously doubt anyone has ever looked at their freshly painted shell and then looked at a box of fixings and gone "oh no...i don't know what they are all off,i'd best sell the car"
Posted 31 May 2014 - 06:47 PM
Good tip thanks.
don't forget the rear subfame bolts in the heelboard.
