Ignition Switch Lube ?
5 replies to this topic
#1 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 19 June 2006 - 12:11 PM
My car did NOT behave this weekend. I took it to the grocery and for the first time in months someone stopped to ask me about it. Wouldn't you know it would choose that occasion to NOT start. The round-body pushbutton starter solenoid used on early cars like mine decided it was time to fail. I had to use a pair of pliers across the solenoid terminals to start the engine.
After putting a used solenoid on my car when I got it home I set out for more errands. This time, again while being watched by curious onlookers, the ignition switch decided to "hang" in the start position... causing my starter to continue to run with the engine running. Oh that's an awful sound.
On outside (door/boot) locks I'm used to putting powdered graphite in the barrel to free things up. I can't imagine you should do that on the ignition lock since there are switch components behind the barrel. What is the prevailing wisdom when and if these locks need lubing? WD-40? Light-weight engine oil? What will loosen things up without being conductive?
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 19 June 2006 - 05:07 PM
dan was talking about this yesterday on another thread (pikey7's chav mobile)
i think he said to use a carbon grease have a look it was only yesterday :lol:
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 19 June 2006 - 05:48 PM
No, I said carbon powder/ graphite powder. The same stuff as for all locks. AFAIK it's recomended for the ignition switch just as for any lock, WD40 or light oil is definitely not good due to the flammability of it.
#4 pikey7
pikey7
  • 3,824 posts
Posted 19 June 2006 - 06:06 PM
You're getting as confused as I usually am Bungle. Not my chavmobile, but Flamereds. A Corsa in my house? Pah! :lol:
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 19 June 2006 - 06:47 PM
So there's no problem with graphite working past the barrel into the contacts? It's been a while since I've taken an ignition switch completely out to examine it.
#6 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 19 June 2006 - 07:23 PM
babys are not good for you :D i need some sleep
