Full Restoration. Waxoil. Where To Apply It?
Posted 01 June 2014 - 07:40 AM
I am progressing with the restoration work of my Inno Cooper and the guy who is changing me the floor panels and sanding the car is asking me where do I want to apply Waxoyl.
I explained him that after apply it underside, we should paint it in the body colour to look as the original cars but is coming to me with more questions:
- Where to stop it? I think sill should not be Waxoiled. Isn't it? He says it would be better for rust protection to stop at the door step.
- He suggest to apply it also on the inside of the floor. Is this necessary?
- Would be good if the boot inside is also protected with Waxoyl?
Regards
Posted 01 June 2014 - 08:24 AM
I would paint first then wax oil to avoid it waxing up
Posted 01 June 2014 - 09:01 AM
Posted 02 June 2014 - 05:59 AM
What about the boot? Should I also apply it inside?
Regards
Posted 02 June 2014 - 07:06 AM
Posted 02 June 2014 - 08:37 AM
http://i1310.photobu...injection-1.jpg
1. There is the forward bulkhead cross member, the floor cross member,
2. the, scuttle corners accessed at the top of the bulkhead near the bonnet hinges,
3 the rear valance closure panels
4. there are 6 coming down from the roof - the door posts which you can do through the hole where the check strap goes
5. the rear subframe, in between/ below where the trumpet sits as this can collect water
6. All of the underneath,
7. battery box, and
8. all the subframe mounting points!
9. Inside the doors especially at the bottom.
Doors - There should be three holes in the bottom of the doors about 1/4" diameter. One in the middle and then one at each end by the curved section Try and drill as close to the radius of the internal door frame flange as possible but don't drill into the door skin. Then paint and then waxoyl (or whatever your choice is) inside the door but make sure your new drain holes are clear.
You can inject Sills through the vents or through the seatbelt holes with an extension probe.You can also stick the tube into the sill from the rear companion bin, take out the liner and you will see the inner sill splits and there is a gap where you can get the lance into.
The vulnerable areas at the front (including the rear of the front wheel arch), at the rear and around the jacking points.
The rear subframe needs protecting all around the radius arm mounting areas and in the trough and webs that run behind the arm.
The A-panels are difficult, being a three layer metal sandwich which is not accessible. Make sure seam sealer is intact where the A-panel joins the inner wing under the car and keep well waxed. Also wax the inner part of the A-panel in the door opening.
Posted 02 June 2014 - 09:25 AM
I am in the process of doing a full restoration at the mo and with all panels I am cleaning, neutralising, priming, seamsealing, then rust prevention paint then a coat of standard paint on top.
A little ott maybe but I'm hoping she'll never rust again (!!)
Posted 03 June 2014 - 06:37 PM
Posted 03 June 2014 - 07:32 PM
Remove the door switch should give access down into the A Panel
Posted 04 June 2014 - 09:35 AM
Inside the boot, no. As long as the boot has been seam sealed around the edges then a decent paint job should suffice.
I would say yes - especially in the battery well. It doesn't do any harm.
