hi guys,
was driving home today and on the way back i realised that the engine oil was low as i was starting to lose pressure at corners, thats all well and good, just needed to top it up but accompanied with that the engine was getting much warmer, any time i turned the engine back on it became hard to start.
nursed it back home and started work on it, when the engine is running with the cap off, every so often it bubbles and swells over and when i put the cap on after re-filling it, the engine just starts to die very shortly after and as soon as the radiator cap is removed it will start picking up again.
ive had headgasket failure before but its not had all these symptoms, can anyone shed some light on my issue?
thanks, Adam
