Supporting Mini To Work On
9 replies to this topic
#1 pinkeknight
pinkeknight
  • 14 posts
Posted 03 June 2014 - 07:19 PM
Has any one ever raised there mini to work on via suspension bolt holes in the rear arches I was thinking of making a frame out of scaff and bolting it through suspension bolt holes
#2 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 03 June 2014 - 07:22 PM
Pretty sure i have seen this done.
You can just make a basic frame easily enough but will probably need to have some sort of outrigger that bolts somewhere else up back to stop the car from rocking on the frame.
The same can be done at the front using steering rack mount points. Use the u bolts to fix a piece of tube where the rack goes and then put legs on it.
Would love to see some pictures if you do it.
Ben
#3 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 03 June 2014 - 07:28 PM
You could if there is no subframe fitted, i usually use my ramps with a few pieces of wood then one piece on top which goes across the floor pan
Heres the link to my ramps
http://www.halfords....catalogId=10151
Ive had one end of a Toyota Landcruiser on them
Edited by cal844, 03 June 2014 - 07:30 PM.
#4 pinkeknight
pinkeknight
  • 14 posts
Posted 03 June 2014 - 07:32 PM
Yea the rear subframe is going to be removed I've got the front on similar ramps and two scaff planks on axle stands under the floor pan but the problem is I've got to replace rear subframe mounting points, inner and outer sills so I don't really Wana risk it on the floor pan when I cut out the sills
#5 Tupers
Tupers
  • 4,173 posts
Posted 03 June 2014 - 07:52 PM
I made these frames from 30MM box section to bolt onto the front and rear damper mounts. It's not pictured but I also added a brace running from front to rear connecting them.
I've used them on several shells and they've proved to be very handy although I am planning another set with better feet and a direct mounting to the captive damper brackets nut on the front.
#6 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 03 June 2014 - 07:57 PM
So thats where i saw it!!   :shades:
#7 Tupers
Tupers
  • 4,173 posts
Posted 03 June 2014 - 08:00 PM
I also use the tube on the steering rack mount method from time to time.
Edited by Tupers, 03 June 2014 - 08:01 PM.
#8 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 03 June 2014 - 08:05 PM
also where i saw it!
Mate, you are an inspiration!
#9 Tupers
Tupers
  • 4,173 posts
Posted 03 June 2014 - 08:27 PM
Not sure I'd go as far as inspiration, I'm just welding pieces of steel together.  :lol:
#10 pinkeknight
pinkeknight
  • 14 posts
Posted 03 June 2014 - 08:29 PM
Thanks for the pics that's perfect, just what I was thinking, when I cut inner and outer sills out I take it I should brace the doors but should I brace any where else
