Inertia And Points To Pre Engaged And Electronic Dizzy
3 replies to this topic
#1 purplesuit1
purplesuit1
  • 88 posts
  • Local Club: Beer Drinkers Anonymous
Posted 03 June 2014 - 11:41 PM
I switched to a Verto engine from a non verto i had before. The new engine has electronic ignition also. I am using this diagram to wire it. I got the car going but after about 5 seconds the wire going from the positive terminal on the coil, to fuse #1 starts smoking and getting really hot. I am kind of stumped. Ive read all around  and i cant figure it out. I still have the old starter solenoid on there with a jumper on it to get power to the starter. If you guys need some pictures of the wiring i can get some on here.
#2 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 04 June 2014 - 02:53 AM
Where on earth did you get that drawing from?
Why is the starter connected to the coil?
#3 purplesuit1
purplesuit1
  • 88 posts
Posted 04 June 2014 - 03:39 AM
Ok well that might be my problem lol. I found it on google, someone posted it on here ages ago. So no cable between starter and coil?
Edited by purplesuit1, 04 June 2014 - 03:39 AM.
#4 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 04 June 2014 - 03:56 AM
I can see why you need it.
Electronic ignition is a straightforward swap,
Bendix to pre-engaged should be simple - for me, join the big cables together at the existing solenoid, take a fused feed from the now spare solenoid down to the new starter - easy. I suggest like this because the inrush from pre-engaged is very much higher than a solenoid.
