Hi
Just wondering if this would be good for running in oil...
http://www.diy.com/n...5?skuId=9227684
It would only be in there for 100 miles then filter/oil change
Posted 04 June 2014 - 07:32 PM
Hi
Posted 04 June 2014 - 07:51 PM
Edited by cal844, 04 June 2014 - 07:51 PM.
Posted 04 June 2014 - 07:55 PM
I was advised by people much more knowledgeable than me to use Castrol Classic to run in on.
Posted 04 June 2014 - 08:36 PM
I certainly wouldn't put that Weasel P**s in a brand new engine just to save £10.
Always use a quality 20w50 mineral oil at all times in a Mini, even for running in.
Posted 04 June 2014 - 08:44 PM
Posted 04 June 2014 - 09:00 PM
I thought that if you use good oil to run in with, it won't bed the bores in?
Posted 04 June 2014 - 09:01 PM
I've always used top quality oil to run in Mini engines for over 50 years and I've never had a failure of the rings to 'bed in'.
Posted 04 June 2014 - 09:13 PM
Fair do's just something I read about bedding engines in.
What's your method cooperman may I ask?
Posted 04 June 2014 - 09:20 PM
Cooperman was actually one person to recommend Castrol Classic to me, for running in. Drop it after 100 miles and start using Valvoline VR1.
Posted 04 June 2014 - 09:24 PM
That's what I do with modified engines, changing at 100 miles and again at 600 miles. Then it's Valvoline VR1 20w50 mineral.
For standard engines I usually run in with Castrol 20w50 for 200 to 250 miles, then drain and fill with the 'good stuff'.
