Weber Manifolds And Vacuum Dizzy?
6 replies to this topic
#1 Earwax
Earwax
  • 513 posts
Posted 05 June 2014 - 11:07 PM
I have a number of differing weber manifolds, of which the majority have no dizzy vacuum port - some have a servo port and this makes sense as in a majority of cases fitment of a weber is about top end performance.
But in the 3 1/2 variety - made for road use and not interfering with the firewall, i have the normal setup as above but i have 1 redline with a vacuum to dizzy port and 1 Cannon with a balancing tube ( albeit within the casting)
My question - has anyone been able to successfully pair a vacuum dizzy advance with the weber induction characteristics and if so what secrets - in my attempt the vacuum connection pulled the advance into the climbing part of the curve and made idle circuits not work.
and secondly - the purpose of the balancer arrangement ( either on weber or SU) -  any info welcome.  Sorry can't provide pictures at the moment am away from home
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 05 June 2014 - 11:35 PM
Trouble is webers are race carbs and therefore no provision is provided behind the butterfly for a vacuum take off, if you use a manifold take off the vacuum see's engine vacuum and therefore not ideal. Its a problem using a distributor with vacuum advance and a weber. whats the spec of the engine ? and what distributor are you using.
#3 albo
albo
  • 204 posts
Posted 06 June 2014 - 12:37 AM
weber`s are race carbs ?,,you mean high performance carbs when needed,, in the correct engine and set up right a weber will give perfect all round performance to meet your engines demands slow and at high speed ,,besides its good looks it`s not realy at home in a mini,, twin weber`s  set up`s as in lets say alfa suds ,,they woud never missed a beat,,it`s a shame they rusted away before they had chance to
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 06 June 2014 - 11:44 AM
a dellorto carb is very similar to a weber carb but does have a vac port on the carb body
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 06 June 2014 - 01:39 PM
Webers were designed as Race and high performance carbs yes, hence no need for economy take offs for vacuum advance, and yes as bungle pointed out Dellortos do have a proper vac take off.
#6 Earwax
Earwax
  • 513 posts
Posted 11 June 2014 - 09:51 AM
Hi  and apologies for being away from computer.. not ignoring replies. I know the full on version of the DCOE 45 was well suited to racing on a long manifold .... i have one of these and it goes great on the Appendix J (Group N) racecar... i suppose i am curious about the 3 1/2 inch manifolds , obviously made to suit the purpose of fitting without firewall mods, but also then presumably made for a more tame style of engine.
I do think a well sorted weber can be reasonably economical but IMO not as economical as a SU.. and perhaps the difference is just the vacuum???    But i do have a short cannon weber manifold that has a internally cast balancer section similar to twin SU manifolds,, and i don't really know what the balance mechanism was for?  To KernowC... the motor is a 1310 road car, so probably on the edge of a 40/45 spec ( was going to try 34 chokes on a 45 to start)
I was not aware dellortos had vacuum connections , i'll have to go back and read my des hammill books.. Cheers for replies
#7 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 11 June 2014 - 08:42 PM
Another Des Hammill book worm lol
