Hey chaps, looking for a little bit of help.
Does anyone know the max thickness of a new pre verto friction disc?
My part worn one wobbles about upto 8mm, the linings are a bit gappy in between the rivets on both sides. Before I go pick up a new one I wondered if this was normal.
Pre Verto Friction Disc Thickness
AntinNZ
, Jun 07 2014 10:01 AM
4 replies to this topic
Posted 07 June 2014 - 10:01 AM
Posted 07 June 2014 - 01:01 PM
Wobbels? if it isnt flat then throw it away as far as you can..
Posted 07 June 2014 - 01:09 PM
How do you mean it wobbles? Whats the 8mm measurement?
Posted 07 June 2014 - 09:17 PM
Well, it's not running true for a start (wobbles like a buckled wheel) and in some places the 'gauge' of the disc is 8mm as a result of the gaps between the friction lining and the centre disc (what the friction lining is riveted to).
So a combination of these issues means that the disc takes up quite a lot of room between the pressure plate and the flywheel, which I reckon is the cause of my clutch binding.
I've never seen another mini friction disc to compare it to, it looks odd to me.
It's the last thing I can think off. No play, or leaks anywhere I've even welded and re drilled all the pivot points etc!
Yup, think I'll order a new un and chuck it in.
Posted 08 June 2014 - 09:19 AM
Get a new one ;)
