Just got my rebuilt mini engine sorted after a few issues and had in rolling roaded so she is going sweet but one thing I noticed is that if you really drive ithard through the gears or slip the clutch in first the clutch stinks its a brand new ap bonded clutch and a brand new med lightened steel flywheel the clutch throw out is set as per the Haynes anyone any ideas or is this normal
New Clutch Smells
Posted 09 June 2014 - 01:15 PM
Posted 09 June 2014 - 01:19 PM
Posted 09 June 2014 - 02:34 PM
Verto system I would slip it a good bit to feed the power in first but when changing gear at higher revs it seems to smell too
Posted 09 June 2014 - 02:36 PM
Posted 09 June 2014 - 03:21 PM
My standard set up never did it
Posted 09 June 2014 - 05:30 PM
If I recalll right the clutch plate / friction plate will need bedding in. Did you do this?
Posted 09 June 2014 - 06:01 PM
We bed ours in by starting the car and doing lots of gear changes, with the shafts out of course(so the engine was only turning the gearbox and pot joints
Posted 09 June 2014 - 06:02 PM
Never heard of bedding in a clutch how is this done?
Posted 09 June 2014 - 06:18 PM
Posted 09 June 2014 - 06:29 PM
The clutch works perfect just smells the odd time
Posted 09 June 2014 - 09:09 PM
Posted 09 June 2014 - 09:31 PM
When you drive it hard through the gears it should lock up and not be smelling then which indicates slip? if you drive it up a hill in 4th gear and just put a small amount of pressure on the pedal does the engine revs rise?
Posted 10 June 2014 - 09:36 AM
Not sure it would do anything - clutches are miles different from brakes where it's necessary to actually get a transfer take place which needs lots of heat/ If you got a clutch as hot as a brake set up.....oooooooohhhhh
Posted 10 June 2014 - 09:38 AM
Posted 10 June 2014 - 09:43 AM
Yeah I know, but I was advised to do it when rebuilding my engine So just driven easy on the clutch the first 100 miles
We never did it on our race engines, but then again : they get rebuilded all the time
Edited by Dusky, 10 June 2014 - 09:44 AM.
