Float Bowl Overflow
3 replies to this topic
#1 nelo36
nelo36
  • 155 posts
Posted 10 June 2014 - 04:22 PM
just getting the mini finished got it started but noticed fuel on floor under car
checked with a torch looks like the float needle isnt working i have replaced the needle and insert but still leaking
it has a plastic float with no way of adjusting depth is there anything that i can do to stop the leak
also is there supposed to be a return to the tank for the overflow or should it just be sitting down the side of the gearbox like it is ?
thanks in advance
nelo
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 10 June 2014 - 04:28 PM
No return to tank just the pipe you have over the gearbox, if you have replaced the needle valve and its still leaking its either the float height is incorrect or the floats got a hole in it. the float height can be adjusted with a small washer under the sea, .if you have no tab to bend
What carb do you have HS or HIF?
#3 carbon
carbon
  • 2,590 posts
Posted 10 June 2014 - 04:35 PM
Also worth fitting an in-line petrol filter just before the carb, if you don't have one already.
Even a small bit of dirt can stop the needle from seating properly and cause carb overflow.
#4 nelo36
nelo36
  • 155 posts
Posted 11 June 2014 - 08:13 AM
hi kernow its a HS4
carbon ill look into a fuel filter would they be that small to fit before the float bowl as i only have 3 inche of pipe
thanks
nelo
