hi all,thinking of making some thicker and stronger tie rods for my mini,has anyone got by any chance a sketch or drawing,or just the dimensions to make these,i work a cnc so wouldnt be a problem to make,also what are the fors and againsts of doing this besides weight gain and what sort of diameter should i go to.pot holes in my area keep killing the tie bars,cheers guys
Tie Rods
Posted 10 June 2014 - 07:24 PM
Posted 10 June 2014 - 09:10 PM
Not worth making them, get these from Mini Spares at around £26: 21A1091
But, if fitting them for rough roads, it is wise to reinforce the front tie-bar mountings on the sub-frame, known as the tie-bar ears, by welding 4 mm thick triangular steel plates to support the 'ears'. If the tie-bars don't bend the loads go into the 'ears'.
Posted 11 June 2014 - 04:39 AM
Maybe better have the tie rods take the clout than having something else more critical take that stress.
Posted 11 June 2014 - 02:03 PM
oh,i see your point guys,cheers.
