Hi, my head used to have a chamber cc of 24.8 but I have had to it skimmed to remove a slight bow in between 2 & 3. This was done a local engine remanufacturer not a race engine builder so I don't know what the new cc's are. I would guess he took of about 0.002 to 0.005 (I asked him to tack off the minimum). How much would you think this has lowered the chamber by/too ? Trying to work out my compression ratios and how much to take off the top of the block.
5 replies to this topic
Posted 12 June 2014 - 05:58 AM
Posted 12 June 2014 - 06:54 AM
Bit of plexiglass and a syringe and you can easily find out the chamber volume.
Posted 12 June 2014 - 06:56 AM
I use an old CD! A smear of Vaseline to hold it in place on the chamber and a syringe to fill it up.
Posted 12 June 2014 - 08:50 AM
That is a brilliant idea ;)
Posted 12 June 2014 - 09:50 AM
So is 1 lieter= to 100 sq CM ?
Posted 12 June 2014 - 10:12 AM
No, 1cm^2 is an area, you're measuring volume.
1,000cc = 1 litre, right?
1 litre is 10cm x 10cm x 10cm, so 10x10x10 = 1000cm^3
1CC = 1CM^3
1CC = 1CM^3
Mini Technical Sections →
Problems, Questions and Technical →
What Size Are These Main And Big End Bearings?Started by scottyboy805 , 19 Jul 2025 ![]() |
engine
Spi Bad Idle And 'tapping' Engine SoundStarted by Simmi Westo , 15 Jul 2025 ![]() |
![]() Help! Water In Oil Question....Started by TerryLee , 06 Jul 2025 ![]() |
Rebuilt Engine Wont Crank With CompressionStarted by Kernreuben , 04 Jul 2025 ![]() |
1966 Mini S - Clutch IssuesStarted by MBradbury73 , 01 Jul 2025 ![]() |
