This may sound like a dumb question(I already posted this on the Auto Register, but figured there may be a little more response here), but I am working on a 92 SPI Japanese Spec AUTOMATIC Mini and the forward gears no longer work/engage. Reverse works beautifully. My question is, can you replace the forward clutch plates without pulling motor like you can replace a manual clutch in a Mini IE: jack up right side of motor, pull radiator out, radiator bracket, and governer housing? Then slip out the forward clutch plates? This may sound stupid, but this car has all the bells and whistles... brake booster, air conditioning, etc. Originally I was thinking about dropping the engine with the subframe out the bottom. Now I pulled the bonnet off and was getting ready to pull it out the top, but curious if anyone has been able to do it the way I mentioned.. I have to replace the radiator regardless, so that is coming out anyway. I didn't want to have to discharge the A/c if I did not have to.
Thanks guys.
Edited by meetthespeakers, 12 June 2014 - 06:38 PM.
